MotorTrend: Electric Vehicles Are Way, Way More Energy-Efficient Than Internal Combus
#61
Ford claims the average commercial van drives 74 miles a day, having more range would waste energy carting around battery cells you don't need. I bet an EV van will save a small fortune in fuel and maintenance costs.
![LeX2K is offline](https://www.clublexus.com/forums/images/statusicon/user_offline.gif)
#62
That's definitely not a van made for anything traveling outside of a city. That battery is smaller than the battery in my Polestar. If you look at the description on Ford's website, it's made to go from point A to the jobsite and back, in other words local travel. Not the correct van for any type of distances past 50 miles. It would work great for say someone who drops off Amazon packages or does other deliveries, or maybe services areas around the business (like a plumber, HVAC tech etc)
![Striker223 is online now](https://www.clublexus.com/forums/images/statusicon/user_online.gif)
#63
![AJT123 is online now](https://www.clublexus.com/forums/images/statusicon/user_online.gif)
#64
That's definitely not a van for 24/7 use...but for a business or company that is running around the city it would work well. A Level 2 charger would fully charge it in about 3.5 hours and a fast charger in an emergency would be 15 minutes or less, so keeping it charged is really not an issue. Long distance or hours of driving would be a problem
![AMIRZA786 is online now](https://www.clublexus.com/forums/images/statusicon/user_online.gif)
#65
#66
My mechanic services a lot of vans for an HVAC company in San Jose, and they spend thousands on oil changes and other maint he performs. These would eliminate all these servicing costs. Of course my mechanic would probably not be too happy about that
#67
Plugging is way, way, way easier. Park the van, in the shop at the end of the day, less than two minutes. Walk away, go home, and the next day it's fully charged or "filled up", whatever you want to call it
#68
And cheaper. Plus these transports drive the same routes every day they know exactly what the range needs to be. Charging is far easier like you say, park and plug walk away.
#69
I think it's hilarious EVs are touted as so reliable when Tesla is second to worst.
Now are we starting to talk about EV busses and stuff? Yeah, easy peasy that would be.
#70
You are mixing up reliability with fit and finish. Tesla's are extremely reliable. Fit and finish has nothing to do with reliability. My boss has already hit 150K on his Model X...zero issues except for fit and finish issues which Tesla eventually fixed. Tesla's are hundreds of times more reliable than any gasoline car. They have less than 200 moving parts while the least complicated ICE has more than 2000 moving parts that run under extreme heat and pressure
#71
#72
Those points of failures are usually very simple stuff like a control board...they don't usually leave you stranded and replaced easily at a very small cost. The more expensive components like drivetrain and battery packs are so robust that they have 10 year/100K warranties. I'm around a lot of Tesla owners, friends, family and co-workers, and other than minor annoyances like a misaligned fender (LOL, had to laugh at that), none have ever had any major issues. Even in the first 10 years, most of the early adopters had problems with stuff like screens, but none ever had a breakdown or major mechanical issue related to drivetrain/battery packs
#73
#74
Uh most engines last 30 years and many companies now have 10/100k warranties. It's usually idiocy that kills engines, just today I was fixing a Kia (surprise surprise....) and the oil had gone TWO YEARS without a change and there was only 1.3 qts in the engine since the owner thought oil changes were a scam, she is a new to me customer and we had a talk after that. Turns out the car is on engine 3.....
In an EV besides the consumable stuff, there is nothing to break. The electric motors can go easily for 300K 400K, the battery packs if properly managed can go for 16 years. The way my brakes and rotors are wearing, I can easily go 100K before a brake job. On the hottest day if I drive my Polestar 100 miles at 100 mph, I can put my finger in the coolant and it barely more than room temp. In an ICE engine, heat and friction are the enemy, in an EV that's just no the case.
I might go through tires more though because of the extra weight
#75
Toyota doesn't, Honda doesn't, Mazda doesn't...I'm not saying engines can't last if you take care of them, but they have much more that can break and are under way more stresses. Case in point, my daughters 2006 Toyota Camry, right now has about 160K. In 2019 I had to change the power steering pump and all the hoses (power steering leak), and the radiator (radiator cracked) and everything associated with it like hoses. $3000 parts, labor. Previous to that I had to change all the belts (timing etc), water pump, sparkplugs, transmission fluid...$1500K. Just last month I had to change all the engine mounts...I had to Zelle my daughter $1500. And I'm one of those who takes care of my cars and changes the oil every 5K and performs routine maint.
The other major issue is that all that you paid for the gas car is only really $500 of parts and about 8 hours of time, there is no way to get parts for EVs or coding for the parts so right now and for the foreseeable future you are forced to pay dealer prices.
