Best Lexus Transmission?
#31
I think the problems with CVTs seem to be partially addressed by using a more powerful engine. I think much of the reputation of CVTs comes from underpowered economy cars that need the CVT to really be able to keep up with traffic. I rode in a Lyft recently that was a last-gen Maxima, and it seemed like the engine has quite the easy life in that car. It didn't drone, just stayed out of the way.
I have driven the Nissan V6 with CVT and it doesn't bother me at all. My Highlander Hybrid with 306 hp and a CVT is completely pleasant.
#33
Understood, but personally I still consider it a CVT as though it may achieve it via different means, it is still acts as a variable transmission without defined gears. Just as in a traditional engine mated to a CVT, it will hold the engine at a desired RPM for power, and that's the part that I find acceptable in a refined, powerful motor, but not in an eco-car/engine. That's the point I was trying to make.
#34
#35
I test drove a Subaru outback 4 cylinder with a cvt and didn't like it. It didn't feel like my maxima did at all. Pretty much like you described it. In the maxima you just didn't notice anything. In the outback you had the loud droning. It just kinda felt like it was at a high rpm and you just kept waiting for that shift that never came. So that's an interesting observation. I hadn't considered that factor.
#36
I agree with this. A CVT in a car without a lot of power just doesn't work for me, as it makes for a noisy racket when the engine is hanging out at high RPMs. But a CVT in a more powerful and refined engine, like a V6, doesn't bother me. The sound at higher RPM is better, and it doesn't need to hang out there so long to get up to speed.
#37
美少女戦士セーラームーン
that's the A650E 5-speed, and it's really about the best transmission i've ever encountered... it's possibly the only case where i'm perfectly happy to not have paddles since the tuning and calibration of the shift points are almost just always perfect, it's like it knows what you want to do before you're about to do it
#38
Anyone ever driven a Prius with the CVT? LOL my foot was on the floor every time I had to use the gas, just about literally.
Agreed that a more powerful engine will not be so bad, but I still want a transmission that actually shifts gears.
#39
one thing i love about the E55 transmission is the steering angle is used in the transmission control unit so it doesn't upshift until the wheel is straightened out, very useful since if you put your foot down even slightly too much through a turn the back will majorly step out lol
#41
Lol that's actually what I was referring to....when I would get one of those at the dealer as a loaner.
You have to floor it to get anything out of it, and even then there is basically nothing.
It's a nice relief to get my LS back which doesn't even need to go above 2100RPM to stay with/beat traffic.
#42
As others have said, the "CVT" in a Lexus or Prius isn't a belt/pulley system at all, so they are in a whole different category from other car's conventional CVT systems. It's nothing more than a planetary gearset, with the ICE on one shaft and a powerful electric motor (600v!) on the other, and with the third-shaft output going to the wheels. The computer looks at the throttle and determines that the ICE needs to run at a particular rpm to deliver that requested power, then commands the electric motor to spin forwards OR BACKWARDS as needed to allow the ICE to run at the necessary rpms. Totally smooth and bulletproof--the planetary gearset is strong and simple. The Lexus RX hybrid handles 300hp output.
#43
Looks like the LS, GS, IS all had that A650E up to 2005. I think those are the cars I'm gonna zone in on, unless anyone thinks otherwise.
The GS might be a nice middle ground for sport/ luxury so I'm leaning towards that.
Do you guys think the LS would be any fun to drive? I understand it's no sports car, but is it enjoyable drive on turns? The ES is fine for me as far as handling. The RX has way too much lean around turns for me though, even when going slow.
#45
Personally, I think 5-6 gears is about the best for an automatic transmission. I haven't felt any of these 7,8,9,10 speeds that I liked the shift behavior in.
