Rear axle shaft spline counts and lengths?
Old Oct 8, 2018 | 04:01 AM
Dfarmer's Avatar
Dfarmer
Default Rear axle shaft spline counts and lengths?
Im looking for some toyota axle shafts that would be compatible with the 100 series front inner and outer joints, however i want them to be a bit longer. Ive taken apart a spare axle assembly, and the shaft between the inner and outer cv joint uses standard toyota 30 spline on all 4 areas. I believe the gs400 and a few other lexus have 30 spline rear axles, however i am unsure of the splines of the actual shaft( the splined rod between the joints). does anyone have this info? I would think that all of the 1uz powered lexus models would use a 30 spline all the way through but I have not been able to find any info on this.
on a side note I disassembled a mkiii supra and found that it had 30 splines on both the inner and outer joint, however the shaft between was a coarse 24 spline.
I believe the 4th gen 4runner/taco/gx have 30 spline shafts all the way through, however thag would limit the length i could attain.
Thanks.
anyoldiron
GX - 1st Gen (2003-2009)
Apr 22, 2017 06:55 AM
GreggyG
Oct 21, 2016 08:29 PM
gameday
Apr 1, 2013 01:33 PM
Horsepwr
Mar 5, 2010 09:10 PM
KingNasGS4
Sep 18, 2009 05:38 PM
