Wires, wires, everywhere: Cluster Swap
Old Feb 19, 2018 | 05:20 PM
speedkar9's Avatar
speedkar9
Default Wires, wires, everywhere: Cluster Swap
I upgraded the instrument cluster on my Toyota Camry from the older 02-04 plain face gauges to the LED backlit gauges of the 05-06 model.
Boy was it a wiring maze, but I eventually figured it out and wanted to share with you all the process...if you were wondering what's involved in rewiring your own cluster.
Here's the video I made detailing the process:
Here's some photos of the process:
Old cluster:
Wires, wires, everywhere: Cluster Swap-8whe4ut.jpg
New cluster to be swapped in. I got it from the junkyard for $35. I also snipped off the pigtails for an extra $6, which will make rewiring much easier and reversible:
Wires, wires, everywhere: Cluster Swap-jgrrade.jpg
I also ripped the female connectors off of another board:
Wires, wires, everywhere: Cluster Swap-jmoelx3.jpg
The next piece to the puzzle is the wiring diagrams of the old (02-04) and new (05-06) instrument clusters. Since the clusters are wired differently I have to swap wires. By comparing the diagrams for each cluster, wire by wire I was able to figure out what wires needed to be swapped.
I tested the cluster to make sure it worked:
Wires, wires, everywhere: Cluster Swap-cwrsltg.jpg
Using the pinouts I numbered each wire:
Wires, wires, everywhere: Cluster Swap-2ybnyhu.jpg
Wires, wires, everywhere: Cluster Swap-akurbab.jpg
The idea is that I'd solder together a conversion harness, so I don't have to modify my car or the cluster to get it work, and I can reverse it if need be, and wouldn't have to deal with depinning the dash harness.
So on I went, soldering up 50+ wires to each pin according to the diagram. One tip is to add solder to each wire and each pin before putting them together. That way, as soon as you touch the two with the soldering iron, they fuse together.
Wires, wires, everywhere: Cluster Swap-ta2cmlw.jpg
I also soldered/heatshrinked on a separate connector for the new rheostat, so I can dim this new LED panel.
Wires, wires, everywhere: Cluster Swap-wflw7ii.jpg
Here's my conversion harness...the huge jumble of wires:
Wires, wires, everywhere: Cluster Swap-cnrpuyo.jpg
For testing, I insulated each wire so they don't accidentally short against each other behind the dash:
Wires, wires, everywhere: Cluster Swap-la21lhd.jpg
Next I wired up the new cluster, literally a plug and play operation. I ran the new rheostat down where the old one was for an OEM like installation.
Wires, wires, everywhere: Cluster Swap-emgcxpk.jpg
With all those wires you'd expect some mistakes to be made right? Turns out I only misplaced one pin for the fuel gauge. After fixing that, everything worked perfectly!
Wires, wires, everywhere: Cluster Swap-ctwredg.jpg
Except the tachometer. I realized that I needed a V6 cluster to make my tachometer read properly on my V6 car. I had the 4 cylinder cluster. So I went back to the junkyard and swapped in a V6 cluster and everything reads correct.
Wires, wires, everywhere: Cluster Swap-jzcbs4l.jpg
The next step was reprogramming the odometer, there's a little 8 pin EEPROM chip on the back of the board that needs to be desoldered and connected to an EERPOM reader to be reprogrammed so it reads the correct mileage for the vehicle:
Wires, wires, everywhere: Cluster Swap-svyptzo.jpg
I used a chip clip test probe to connect the SMD chip:
Wires, wires, everywhere: Cluster Swap-c2vigns.jpg
Connected it to my home made EEPROM reader:
Wires, wires, everywhere: Cluster Swap-o1rmmqr.jpg
Which plugs straight into the serial port on my pentium 4 computer:
Wires, wires, everywhere: Cluster Swap-6b2o54k.jpg
And that yields a hex dump, to which we can decode the odometer reading here in line 60:
Wires, wires, everywhere: Cluster Swap-9lwfbb5.jpg
By editing the HEX characters, I was able to reprogram the 4 cylinder cluster.
Now I have more details in my odometer reprogramming video, which you can see here:
Unfortunately during desoldering, a blob of solder dropped onto the main cluster chip on my V6 cluster. I tried saving it but it was toast:
Wires, wires, everywhere: Cluster Swap-etqs59o.jpg
I guess I'm back on the hunt for another V6 cluster! I'm still enjoying the 4 cylinder cluster which is much, much better than the old cluster it replaced!
Enjoy!
Old Feb 19, 2018 | 07:22 PM
Nice work, too bad about explode part. Does the cluster use a fluorescent tube for back lighting like the early ES clusters or LED?
Old Feb 20, 2018 | 06:02 PM
speedkar9's Avatar
speedkar9
This cluster uses LED backlighting.
Old Feb 21, 2018 | 07:23 AM
bagwell's Avatar
bagwell
Good lord, tons of work for a cluster swap!
good job!
Old Feb 21, 2018 | 10:39 AM
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
Looks way better! Well done sir
Ori85
Sep 24, 2023 04:46 AM
Solowing
Sep 7, 2016 02:36 AM
DrRobot
IS - 1st Gen (2001-2005)
Nov 22, 2012 02:22 PM
talgrl626
Jan 12, 2005 03:44 PM
allkingz
Jul 7, 2004 10:11 PM
