possible head gasket issues need assistance
Old Mar 1, 2014 | 07:25 PM
1sik2jz's Avatar
1sik2jz
Default possible head gasket issues need assistance
My sc300 recently has nearly took a crap on me it's lost all power and I see no signs of losing coolant but has no power at all it only goes to 20mph in low gear once in drive has no power won't even make it up a driveway hardly any suggestions
Old Mar 1, 2014 | 10:53 PM
gtstcactus's Avatar
gtstcactus
um perhaps the transmission is stuffed?
Do SC300's have a limp home mode?
Old Mar 2, 2014 | 12:40 PM
mmarshall's Avatar
Welcome to CL as a new poster.
With most automatics, the Limp-Home-Mode feature is ususally in second gear, not low. That allows a start-up from rest without the engine straining too much while also allowing something that, while not fast (or even keeping up with most traffic) is somewhat faster then a grandma-crawl.
As far as head-gasket issues go, often a head gasket problem will allow coolant/anti-freeze to get sucked into the cylinders and vaporize out the tail pipe as a white steam/smoke. If you don't see that out your exhaust pipe, it sharply minimizes (but does not completely eliminate) the chances of it being a head gasket. And don't confuse that kind of steam with the cloud of water/steam out the tailpipe that is often visible on catalytic-converter-equipped vehicles with a cold exhaust system....that's more or less normal, and usually goes away when the engine and exhaust heat up.
Old Mar 2, 2014 | 07:30 PM
1sik2jz's Avatar
1sik2jz
yea it doesnt show smoke at all and it does not overheat at all my guess is the head gasket is lifting little by little and causing compression issues i could floor it and the car jus shakes ugly and sounds like its straining if i even get the front stuck in a driveway it wont even have enough power to pull up the driveway
OMAHA
14
Jul 12, 2017 08:54 PM
rdm20fan
Dec 9, 2014 09:23 AM
ErickBoy54
Oct 15, 2006 10:24 AM
LexieLS
Jul 17, 2006 08:58 AM
ken8817
GS - 1st Gen (1993-1997)
Jun 29, 2006 08:24 PM
