Unintended Sudden Acceleration of an Hyundai Elantra Ended in High-Speed Crash
#46
dicer there have been no (ZERO) credible reports of 'unintended acceleration'. while there's a lot of code and processors in cars, they undergo extensive testing, plus they build on prior code which has also been tested. there's independent testing, and of course there's feedback from customers and dealers which is taken seriously by car makers (obviously). there's probably more safety tech and failsafes and fallback/redundancy in cars than in airplanes.
#48
According to an article it said a modern Luxury car has anywhere from 70 to 100 micro processors, and uses 100 million lines of software code. And went on to say a Mercedes s class navigation system alone uses 20 million lines of code.
All here on this thread and even some youtube videos seem to think we are still dealing with cars of the 80's and below. Sorry not the case and its going to get worse on newer cars, and is the case on many new cars now, what I'm talking about is electronic computer control of everything the driver inputs to control the car.
EVERYTHING the driver touches to make the car work is run by computer. Steering was the last hold out but even that is in the equation, with auto parking and lane hold features. Turn the engine off when the gas goes to the floor ? How when its all run by the computer, the brakes the transmission and on and on. The only hope maybe a park brake but then maybe there is an override on that and if its just a small shoe arrangement like the old LS400's and some other cars at a high speed they will fade like shoes on ice so they won't do much.
Anyway I posted this above it was on 60 minutes last night it started out as computer hacking and they showed an eye opening hack of a car being driven.
http://www.cbs.com/shows/60_minutes/
2-8-15 show
2-8-15 show
BSOD can happen anytime, but that is why we have a physical power button to turn the computer off.
#49
Unfortunately this is not always true. If the engine remains at WOT and the person pumps the pedal a few times then vacuum to the brake booster gets depleted and stopping power is reduced enough where the engine does overpower the brakes.
#50
That's right -- just turn off the ignition by turning the key or stabbing (and holding) that engine stop button.
#51
Not everyone does this, they panic or whatever and pump the brakes. That's why a throttle override makes so much sense, protect people from their own incompetence. Either way I don't understand why in so many of these cases no one tries to put the car in neutral. Sure they say they tried and it didn't work but I don't find this credible.
#52
most people are just outright terrible drivers that have had zero emergency skills. I wonder how many people actually have the correct seating position so they can apply full braking power of their foot for a panic stop. There are several options at their disposal to mitigate and stop a situation like this and for the most part are not used at all.
#53
And how the code was reprogrammed. In new cars after a certain year the "mechanical shifter" is no more mechanical than the accelerator pedal is, and if there is a mechanical link its only to the park pawl and that will not engage at speed. At speed the small surface area parking brakes become ineffective because of fade. And besides try to drive your car over 50 mph and yank the parking brake, I bet you spin out of control especially if you are entering a turn.
Again your all thinking of cars from the early 90's and lower years. It is the computer age in cars now.
Here are some good links for electronic parking brakes.
https://www.google.com/patents/US5370449
https://en.wikipedia.org/wiki/Parking_brake
scroll down to electric park brake.
http://www.audiworld.com/forums/q5-s...brake-2871442/
In this forum read the "electromechanical parking brake"
Oh and ABS is operated via a computer, everyone thinks runway is just a gas pedal sticking. Again watch 60 minutes show.
Here you go the only mechanical link in this manualish type transmission is to the parking pawl. The shift collars are all moved by way of shift solenoids. They mention a manual mode, but even then its done just like anyother modern automatic transmission, by electrical shift solenoids. And a computer is allowing the different modes.
#54
I am curious: will the brake override work even if you do not remain on the brake pedal for any great length of time, like if you are pumping the brakes?
But I am willing to bet that in a panic situation that more people will floor the brake pedal than pump it; pumping it requires too much thought.
Regarding putting the car into neutral (on traditional automatic transmissions)... I am wondering if drivers these days (especially if they did not receive formal driver's education training) would know that "N" is neutral and that it removes the mechanical link between engine and driven wheels?
Could this be one reason why car makers are making it more difficult to shove the transmission into neutral?
First, Ford made you depress the button on the gearshift lever to move from D to N, instead of merely pushing from D to N.
Then we have the hockey puck on Jaguars and new Chryslers. It is less intuitive (requires more thought in a panic situation) to turn the puck than to tap the lever.
Then we have the push-button gear selector on new Lincolns, and new Hondas. Again, it requires more thought to find and push the correct "N" button than tap a lever. And in typical Honda fashion, is it as simple as pushing the "N" button on the gear selector (other buttons on Honda's selector are not simple push buttons).
Nothing is as simple as a gear stick (since you can do it by feel), whether it is the traditional straight pattern, the current Toyota zig-zag pattern, or the smaller sticks that the Prius and new BMWs have.
#55
The brake over ride will work, as soon as the ECU sees a signal from the brake switch it prevents the engine from producing full power. As for people not knowing what the N does, well they should not be behind the wheel if they don't know the most basic info.
#56
second, we have no way of knowing how the car was modified, and even if not modified, what the 'hacker' knew about the car that he might not typically know about a real 'target' (like vin, firmware and hardware revisions, etc.).
seemed to me the darpa guy was a good show man, justifying his huge budget. if his stuff is real, why would he need to get on 60 minutes? in fact, why get on 60 minutes in any case and tell the world, unless you're bluffing?
#57
And, of course, the idea of buttons is nothing new. Back in the 1960s, I learned to drive on a Plymouth with push-buttons. Most American-designed Chrysler products had them from the late 1950s until 1966, when traditional levers replaced them. And the ill-fated Ford Edsel used them, in the steering wheel hub, during its first year. Not all the Chrysler or Edsel push-button transmissions had a PARK function, but those that did used a slide-lever that worked up or down and engaged park.
#58
And the mention of no credible reports on the acceleration deal?
http://abcnews.go.com/Blotter/toyota...ry?id=22972214
Hiway patrol man and family in a lexus. Out of all people other than a professional race driver he would not panic and would first do what EVERYONE says to do in that sort of situation.
What is interesting about this, long before all that acceleration stuff was in the news, my little car I installed a cruise control in would constantly have the accelerator stick. No big deal, and before that in my younger days had another old junker that had a accelerator spring that would pop off and go wide open throttle a quick toe under the gas pedal fixed the problem. So I really don't buy the floor mat answer to the problem.
Has the problem ever happened to a mechanic or old timer?
#59
-0----0-
^ It was shown that this particular incident was due to improperly installed floor mats (one on top of another) that slipped and got jammed under the accelerator.
The only person that "proved" that unintended acceleration could've been a computer issue was a guy that hacked the heck out of a Camry to override all of the safety mechanisms
#60
actually i did. apology accepted.
that 'demonstration' with leslie stahl was a lame piece of security theater. first, she has about as much technical know how as my dead grandmother.
