Chevy Volt MPG question
Old Apr 4, 2010 | 07:48 PM
SLegacy99's Avatar
SLegacy99
Originally Posted by spwolf
it is very unlikely that Volt will get anything above 40 mpg when batteries are depleted. Even 40 mpg will be victory, as it is less efficient system than Prius when batteries are out, and you have small petrol engine, powering electric motors which then power very heavy car. You have two added things in the equation - extra loses from petrol>electric and weight of car with useless batteries.
I disagree. The Volt has a smaller engine, running at an optimal RPM, powering the car. It has one task. The 1.8L in the Prius is not only larger and older, it has multiple functions, and presumably more influenced by the driver's right foot. Additionally, the Volt has regenerative brakes and more efficient Li-ion batteries with a charge range wider than the 40 to 60% of the Prius. Volt is expected to be 300 to 400 lbs heavier than the Prius. Significant, but not enough so that I would write it off yet.
Old Apr 4, 2010 | 08:44 PM
-J-P-L-'s Avatar
-J-P-L-
I also disagree. Remember that the Volt's gas engine is never powering the car.
It always runs on the battery power, which even though it will be regenerated by the small gas engine, still runs much more efficiently than if powered directly by a gas engine. If that makes any sense. In other words, it takes less power to regenerate a battery than it does to power a car itself. Therefore, the Volt could very well get better than 40 mpg in regeneration mode.
Old Apr 4, 2010 | 10:55 PM
Allen K's Avatar
Allen K
-0----0-
CL Folding 25,000
Plus, unless you're flogging it, the batteries are going to recharge through the generator and the regenerative brakes and when the batteries reach a preset charge level, the generator shuts down again. It's not like once the initial charge is gone the gas engine has to run until the car is plugged in again.
barbaresh
Hybrid Technology
1218
Mar 3, 2026 09:14 AM
zmwu
14
May 5, 2017 07:20 AM
HotShotEng
Jun 25, 2016 09:13 PM
WaGoNiSt
Oct 11, 2006 04:42 PM
RX300wannabeIS300
RX - 1st Gen (1999-2003)
Aug 23, 2003 06:22 PM
