Powerhouse G35 sedan. This thing makes more power than an Enzo
This is the car of a fellow G35 owner. I have met the guy once at a local shopping center. He is the most hardcore G35 sedan owner I have ever seen or read about. This thing dynos at 650 hp to the wheels on race gas. Thats amazing!!!!!!!!!!
Here’s a current mod list:
Engine & Drivetrain
649whp and 651wtq
- Wiesco 8.8:1 pistons
- Tomei Rods
- Cosworth bearings
- GT Motorsports Heads
- Jim Wolf S1 Cams & Valve Springs
- Greddy Twin Turbo Kit with 2000 degree coated manifolds & turbo exhaust housings
- Greddy Front Mount Intercooler
- HKS SSQV Blow Off Valves x3
- Custom air intakes behind front grille with AEM Dryflow filters
- NGK Plugs
- Kinetix SSV Intake Manifold
- Nichols AutoFab Oil Catch Can
- Greddy Oil Cap
- Custom Grounding Kit
- Sun Hyper Ignition & Hyper Voltage systems
- AMS 50mm Radiator
- FAL Fans
- Earl’s 6x13 Oil Cooler with Spal Fan
- WR Power Steering Fluid Tank
- Greddy Profec B SPec II Boost Controller
- Turbo XS UTEC with tune by UMS Tuning
- Turbo XS Tuner
- JDM Right Side Battery Cover
- Carbon Fiber Battery Covers
- Rogue Engineering Short Shifter
- Carbonetic twin plate clutch and flywheel
- Upgraded power steering cooler
- Carbon Fiber 350Z Engine Cover
Exhaust:
- Vibrant 3" downpipes with 2000 degree coating
- Wastegate dump tubes 2000 degree coated & routed back into down pipes
- Custom Nichols AutoFab dual rear muffler, dual 3" exhaust (Only dual muffler G35 sedan of its kind)
Suspension:
- KW V2 Coilovers
- Stillen Sway Bars
- SPL End Links
- Rare JDM Rear Strut Bar
- Richie’s Front Strut Bar Covered in Carbon Fiber
- GT Spec Rear Lower Tie Brace
- GT Spec Rear Lateral Arm Brace
Brakes:
- Front: Rotora 380mm x 34mm 12 Piston
- Rear: Rotora 355mm x 32mm 4 Piston
- Rotora C2 pads
- ATE SuperBlue Fluid
Exterior:
- Kurookie front bumper
- Nismo Side Skirts
- Nismo Rear Valance
- Custom Made Headlights including:
S2000 Upper Headlight Projectors & Acura TL Bi-Xenon Lower Projectors with BMW ZKW lens
6000K Phillips Ultinon HID Bulbs
AAC CCFL Angel Eyes
Exterior matched paint
- iForged Aero 20x8.5F 20x10R
- Nitto NT-05 255/35/20 & 275/35/20
- 20% tint
- 2006 Taillights tinted & clear coated GT-R style
- JDM Bump Style Clear corners with 30 LED PCB boards in each
- 3M Clear Bra on bumper cover, hood, A-pillars, side skirts, headlights, door edges, rear bumper, and lower half of doors
Audio/Video:
- Eclipse AVN 6600 Navigation Head Unit with Sirius & iPod.
- Eclipse back up camera
- Headrest TV’s
- JL Audio 1000/1 & 450/4 amps
- Stinger 15 farad capacitor
- 2 JL 12W6v2 Subs in fiberglass enclosures
- Focal K2 Mids & highs
- Optima Red Top
Interior:
- Black Suede Sparco Milano 2 Seats
- Forged Performance Shift ****
- AutoMeter Nexus gauges in custom center dash & A-pillar pods (Boost, EGT, Wideband A/F, Oil Temp, Oil Pressure and Fuel Pressure) The controller is behind the glove box.
- All LED Interior bulbs
- KP Technologies VDC By-pass Module
- Mirror Tilt Module
- Window Module
- Valentine 1 with Mike’s Mount
Alarm:
- Ungo 872 2-way remote start with window modules, interior temp sensor & trunk pop.
Engine & Drivetrain
649whp and 651wtq
- Tomei Rods
- Cosworth bearings
- NGK Plugs
- Greddy Oil Cap
- AMS 50mm Radiator
- FAL Fans
- Turbo XS Tuner
Exhaust:
Suspension:
- KW V2 Coilovers
- Stillen Sway Bars
- SPL End Links
Brakes:
- Rotora C2 pads
Exterior:
- Nismo Side Skirts
AAC CCFL Angel Eyes
- 20% tint
Audio/Video:
- Headrest TV’s
- Optima Red Top
Interior:
- Window Module
Alarm:
the dyno on pump gas wouldnt let me post , but the car is putting down 516 hp and 528 ft/lb to the wheels. Remeber these number represent what is actually being put to the ground. Add another 10-15% for crank power estimation
yup its TIMMAH. This dude had had t 2 or 3 forced induction set ups on this car. I know he had a Stillen stage 3 super charger on it, but he wanted more power. Then he switched to a turbo set up. He lives near me so I see the car around a lot. I just didnt know how much power this thing was putting down
