Volkswagen Unveils Cleanest TDI Engine Ever
BlueTec alliance launch in 2008
A VW Jetta TDI fulfils the most stringent worldwide exhaust gas thresholds with its nitrogen oxide post-treatment system developed by Volkswagen. The USA market launch within the BlueTec alliance is planned for 2008.
Volkswagen unveiled the cleanest ever TDI engine. First test drives demonstrate the high potential of Volkswagen technology, which consequently reduce nitrogen oxide. In the VW Jetta a new 2.0 litre Common Rail diesel engine with a nitrogen oxide reservoir catalytic converter was used, which complies to the Californian emission standard “Tier 2 / Bin 5”. These requirements are considered the most stringent worldwide. The first production run of the “Clean TDI” with nitrogen oxide post-treatment system will be made during 2008 in the USA.
The central theme of the entire concept is the reduction of nitrogen oxide. The engineers in Wolfsburg reached this goal through internal development of the motor and the use of new emission post-treatment technology. The result: up to 90% less nitrogen oxide emissions (NOx).
This drastic reduction was necessary in order to comply with the “Tier 2 / Bin 5” norm, which applies to California and four other states in the north-east of America (Massachusetts, New York, Vermont and Maine). This norm limits nitrogen oxide emissions to 70 mg per mile. In order to comply with this standard, completely new emission * treatment technology was necessary. Volkswagen has thus developed two systems connected to the oxidation catalytic converter and the particle filter in the exhaust system.
New NOx reservoir catalytic converter technology is currently being tested for car models below the Passat class. Nitrogen oxide is absorbed like a sponge, leading to a high level of efficiency. As with the particle filter, the system is regularly cleaned without the driver noticing. To do this, the engine management system changes operation modes for a few seconds.
Larger and heavier models feature the Selective Catalytic Reduction (SCR) catalytic converter. The central element is an aqueous solution such as AdBlue, which is transported in an additional tank made from stainless steel or plastic. 32.5% of this solution is comprised of urea, and is continuously injected into the exhaust system in front of the SCR catalytic converter using a metering valve. The dosage is made according to the gas emission stream.
The urea solution is finely atomised by a grille and is converted in hot exhaust gas into ammonia before it reaches the catalytic converter. The ammonia then reacts with the nitrogen oxide in the catalytic converter and separates it into nitrogen and water. Unlike pure ammonia, AdBlue solution is non-toxic, odourless and biodegradable. Volkswagen intends to install the additional tank so that the car can be driven without main*tenance between two garage inspections - the garage simply refills the tank at the next scheduled inspection date. According to American regulations, the complete system must be fully functional for at least 150,000 *miles.
BlueTec is a joint project of the German car manufacturers Volkswagen, Audi and DaimlerChrysler, intended to establish the diesel engine further in the American car market. The manufacturers are convinced that the diesel motor is the clean, low-consumption alternative for future car use, which is backed up by current economic and political condi*tions. Each of the manufacturers involved in the BlueTec joint project is working on individual technical solutions for stringent exhaust gas emission standards and plans to market these independently.
Volkswagen is definitely the diesel pioneer in the USA – more than 800,000 diesel cars from Volkswagen have already been sold there.
Impressive!!!!
Well, yes, the bluetec technology is impressive, but it probably would have not been possible without the new low-sulfur diesel fuel now available...so petroleum engineers deserve part of the credit. And thet new low-sulfur diesel fuel, at current prices, is NOT cheap.....though the price may come down as more of it is produced and distributed., from economies of scale.
Super Moderator
I forgot what offhand they are selling diesel at down here, but I am sure it is more than the U.S., and the unfortunate aspect until recently is that we had high sulfur diesel, but hopefully since Pemex gots its butt in gear and came out with better gas, I hope to see a lot more diesel models from Europe here.
