Let's do a GB on some blinker fluid.
http://www.kalecoauto.com/fluids.htm
My blinkers are sluggish, let's see if we can all get together and get some
umm... wondering if i can get the regular organic blinking fulid with 1.99$. this synthetic cost 5.99$ and i usually change my blinker fluid every 100K blinks ( 150K blinks is recommended!) other wise the blinker get over heat and dull the blinking preformance makes the blinkers very sluggish!
i need the speedometer fluid as well
Originally posted by ChrisFL
Yeah, running out of blinker fluid sucks.
I ran out once on my right blinker after work, so I had to make left turns all the way home!
Originally posted by V8_Aristo
Good thing you weren't on the freeway when you ran out on your right blinker or else you wouldn't be able to get off.
(my appologies to the NJ members
-Motor Block Oil Bypass Kit-
Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through your motor block?
"O" Pipe
You've heard of the Y pipe.. the X pipe.. the H pipe.. nothing can touch the O pipe!!! It provides 100% backpressure feedback on ALL engines!!
"O" Pipe
