Build Threads Details on Club Lexus LS460 owner vehicles
07 ls460 project
Old Nov 30, 2020 | 01:44 PM
lwphat66's Avatar
lwphat66
Originally Posted by loudls460
No dyno run yet but I did take the car to a local track, my best pass was a 13.51@104 with a 2.14 60ft. Don’t have enough tire to actually launch it, I’m on 235 Michelin All Seasons. With a better tire it’ll easily go 13.2-13.3 at the same mph.
That's awesome you were able to get in to the 13s! My motor and exhaust are both stock, but I did recently install the Red Bullet VVT solenoid valves. My best 0-60 is 5.80 seconds and 1/4 mile in 14.02@102 - not on the track but using the Dragy GPS app. Know what you mean about the launches (I'm on 245/19s), as I've been trying different suspension settings as well as dialing back my Pedal Commander. But I'm still getting some wheel spin, so I'm working on different style launches to hopefully get in to the 13s as well.
Old Jan 3, 2021 | 04:07 AM
lwphat66's Avatar
lwphat66
Hey Mike, check out my fastest times to date with my 2007 long wheel base. No tune, gearing, exhaust, or motor work/mods. Considering exhaust work cats back but I prefer to keep it on the quieter side even though yours sounds good. Take care brother, and keep us posted after you hit the dyno.
Old Jan 4, 2021 | 07:10 AM
L's TLS's Avatar
L's TLS
I have a similar setup on my 07, 2.5 inch straight pipe from the primary cats back with an x-pipe about halfway back. I’m going catless with a tune from Steve at Sector7 Tuning and once he figures out how to get the car to hold 6th gear without downshifting it’s going on a dyno. With his tune and an unrestrictive exhaust I can imagine 30+whp easily which would put it at about ~415hp, will post real numbers soon. A supercharged car with a proper tune should easily make over 500 at the crank, no reason it shouldn’t when ISFs and others are making over 500 at the wheels with boost.
Any sound clips of your exhaust setup?
Old Feb 8, 2021 | 06:56 PM
loudls460's Avatar
loudls460
Yeah, they’re on my YouTube channel! https://youtube.com/channel/UCFHvqCJ3QWRYAN-ZJd4ENag
Old Feb 8, 2021 | 07:26 PM
loudls460's Avatar
loudls460
That’s definitely not bad for a pretty much stock L. The best I could get stock was 13.85@102 with a 2.28 60ft on the street but did manage a 5.35 0-60 with careful throttle input, traction has always been a problem with this car lol. The stock exhaust is pretty restrictive but you can also shed quite a bit of weight changing it out, the L is even more disadvantaged with weight. The dyno should be soon but I want to get the car weighed first to have most accurate numbers possible.
Old Feb 9, 2021 | 06:08 AM
lwphat66's Avatar
lwphat66
Very nice brother! Could you post those Dragy stock times here when you get a chance, thanks.
Old Feb 9, 2021 | 06:48 AM
loudls460's Avatar
loudls460
I was mistaken, the 5.35 was right after I got it tuned. 5.58 was my best 0-60 stock. These runs were done June 2020 in the evening in central Texas. I usually have a DA of 3k+ so it’s not as good as it could be. Only mod at the time was catback exhaust.
Old Feb 11, 2021 | 05:03 AM
lwphat66's Avatar
lwphat66
Thanks, that's what I was looking for, pretty much the improved performance with the catback exhaust alone. So the Red Bullets alone are almost the same (improved times wise) as the catbacks. Appreciate your input brother!
Old Feb 11, 2021 | 06:03 AM
loudls460's Avatar
loudls460
I’m not exactly sure about that because we can’t compare our numbers directly without a Density Altitude correction factor cause mine is significantly higher and even then it’s not perfect that they’re estimates. Unfortunately I don’t have 100% stock times to see the actual improvement which I think is the important part. But I’m interested to see what improvements a catback would net you, imo the weight difference alone is worth it considering a rear muffler delete shaves 40lbs by itself.
Old Feb 11, 2021 | 07:26 AM
lwphat66's Avatar
lwphat66
Yep, first rule of modding, get a stock baseline. Removing the stock exhaust will help negate some of the added weight of the LWB and is definitely on the horizon somewhere. However, my thought is that if it sounds fast, it should be fast. And the 460 is not fast to me. Since I prefer a more stealthy sound for my 460, the exhaust system is not high priority. Have you considered the Red Bullets? There's a brand new pair for sale by L's TLS in the classifieds.
Old Jun 21, 2021 | 09:58 PM
ThomBradie's Avatar
ThomBradie
where the heck do you get a tune. I do t a straight pipe also. Looking to increase HP not sure where to start
TOPENDMS
CL Vendor Products for 4LS
Jul 4, 2023 07:18 PM
Owczar
Aug 13, 2017 03:02 PM
GFerg
Oct 27, 2006 04:25 PM
GSsnarl
May 5, 2006 09:22 AM
