Refresh & Upgrade time... how many F-sport badges can I put on my 200k mile IS350?
#31
Bling level over9000
About the idle - you might want to swap the intake manifold & surge tank gaskets, and all the piping around them. Any misfires/roughness during cold starts? I feel like a fool for not looking this up earlier... a few days ago I was in the garage and was tightening down the surge tank after I decided that I shouldn't be taking it off at 3AM after all... started the engine, no random rare misfire. It was doing that once every 1000 or so combustions, and only while "cold" starting (not necessarily cold engine, just cooled down manifold I guess), no issues whatsoever once any amount of power was applied (even charging the battery or just revving up)... Anyways, I guess you learn something new all the time, even though it should've been quite obvious to me that a small vacuum leak is a VERY good explanation for that kind of condition >_<
And yes - no oil burning whatsoever (10k miles 0w20 first time, don't kill me), no coolant loss, no hesitation, nothing.
Figures that those hoses/gaskets might go bad over time, given that no oil or coolant is supposed to reach them & condition them.
Not sure if I've said it, but consider changing your seat's polyurethane cushions (PAD, FRONT SEAT BACK LH/RH& PAD, FRONT SEAT CUSHION LH/RH, rear... etc). Haven't done this, but it's on my to-do's, plus dying parts of the leather where the dye has worn off... luckily no cracks yet, hopefully leatherique is helping there
#32
#34
Lot's of updates:
- Coilovers are installed (set to same height as H&R springs)
- IS-F steering wheel installed
- F-sport **** installed
- Engine idle issue fixed (it was a cracked hose)
- Wheel well cladding replaced
Christmas came early this year! Will be installing these and getting the wheels refinished soon. Also doing some new windshield trim, di noc on the interior trim, replacement stock rear spoiler, new foglights... still looking for an f-sport exhaust if anyone has a lead one.
bbaugher47 (09-23-19)
#35
Way off topic; more of a reminder to all but keep those receipts in order if something bad happens. Also keep an eye on local sales for 350's in good shape and print to file / keep with your receipts. One air bag deployed and these things can be totaled the way things go these days!
Merry Christmas!
Merry Christmas!
autovation (09-23-19)
#36
It's getting real now.
2013FSport (10-15-19)
#38
Currently running 235/35/19 Front & 265/30/19 Rear Michelin Pilot 4s, great street tires. I have run 275/30 in the rear and will probably go back to that when the next set goes on.
#39
Definitely about the best street tire you can get. I've been running Hankook Ventus RS4s, which are the best performance tire I've ever ran PERIOD. But we're about to be hit with cooler temps for the first time this year tomorrow. I'll see if these sticky tires turn into bricks.
#40
I'd like to see a comparison between ^^ and my BFG's. G-Force, Comp-2, A/S << it snows here on occasion and they did well when they had tread! That said, I'm sure there are better performance tires.
#41
Tell us how they do towards end of life cycle. And how many miles you've gotten from them.
Well, it was 42 degrees outside this morning. I was parked in a garage though; but the concrete foundation I'm sure was stone cold. Regardless, the tires are still holding quite nicely, even when this cold.
Before these RS4s, my previous favorite tire was the BFG KDW II. Actually still have a set on my factory 18s in my garage.
Once the rear RS4s wear out, I've got a set of Nitto Invo 255/35s to try out. Never ran this tire before; so I'm curious how it does.
#44
Car is coming along quite nicely. Any pictures with the coils on? I’m interested in seeing your ride height.
#45
The dash is out and getting new LED's installed with blue big needles & red small needles. I'm trying to order a set of 2012-2013 headlights but not sure the part numbers of everything that needs to be ordered.
bbaugher47 (10-21-19)
