Vince's NA-T college fun build
#91
Congratulations about your dad - what a blessing! Cherish that **** because life truly is short.
#93
Thank you so much guys for the wonderful words! Love this community. BUT, back to the chinese turbo issues many predict aha. So. My turbo housing has no ports or holes for vacumm lines.... heres a pic
I hope Im not mistaken calling this the housing. Also I looked all over the turbo and found nothing on it either. What can i do to run this turbo?
#95
Also another question. Wbat size studs and nuts should I use for oem oil return spot? I seen on other threads they just list the part numbers but maybe you guys figured out something new?
#96
Fuel injectors are in. The rail is tightened down and is keeping in place. Got the nuts and studs coming in from toyota soon. Now just gotta cap off the EGR lines
#97
#100
It is possible. I personally prefer to get the boost reference from the compressor housing, but I will acknowledge that there are differing lines of thought on this.
One thing against using an intake reference point is that the wastegate diaphragm is not designed to see vacuum... It could cause issues with your wastegate down the line.
#101
mrmj2u (06-19-19)
#103
Use this instead:
https://rover.ebay.com/rover/0/0/0?m...2F131610413005
MNtyler (06-21-19)
