Jose's 97 Soarer Restomod Build
The braided SS hose upgrade will be a HUGE improvement. I just swapped mine out on my '92 w/fresh fluid and couldn't believe how much firmer and sportier the brakes feel after getting rid of those old rotting hoses.
BLK13X (07-21-18)
Mortgage Slave
Below picture is of one of the lines I didn't have an issue with. The screw-in fitting that connects to the body side brake line doesn't want to play nice on the other lines, even though they all share the same thread pitch and diameter
Here is the fluid after sitting for a while. Yuck!
Mortgage Slave
Thanks man, I've been rolling around with just the enlarged airbox opening for years and no issues. Drill four points in the front and either use a jigsaw or dremel w/ cut off wheel
The rest of the intake mod is on the backburner for the meantime, toying with some other ideas for it.
So it's arrive and I got it to work. The pump itself works fine, but the adapter took a while to sit up properly against the neck of the brake fluid reservoir. They recommend letting the bleeder sit for about 30 to 40 seconds to make sure the pressure doesn't drop, I left it for 2 or 3 minutes instead. The connector between the bleeder unit and adapter is a screw fit, I'm looking to get a quick connect as this is where I had the most issues with pressure loss, probably also look at getting (or making) the adapter for the reservoir.
Mortgage Slave
Nice man I'll keep that in mind I've been away for the past week so hopefully will get some time this week to get into it again.
The seal to the master wasn't so bad but set up can be a bit of a pain so it may pay to get the adapter that you posted up, it has the three prongs to tighten up against the reservoir which is nice and will eliminate any re-seating when building up pressure... that in itself seems like it's worth the price. Still,my biggest issue was in between the pump and the adapter where they connect but since all I own are Toyota-based I may just wrap some plumber's tape to seal a little better.
Mortgage Slave
Not much to update except she's passed inspection and is registered.
Next up I'm looking at an R154 swap and new LSD. My coilovers are quite firm for the street (HKS Hipermax Pro's... less than 2000km on them) so looking to replace them with something a little more forgiving, haven't decided which ones yet. Also still need to fit my Celsior/LS400 front brakes.
I'm over the moon to be back in the Soarer again
Absolutely love this car and great mods so far. You'll be ecstatic after adding the LSD - best mod I've done to my car thus far (if you're into track days and hood rat activities that is). If you decide to sell those coil-overs shoot me a PM.
BLK13X (10-18-18)
Mortgage Slave
Cheers! Yeah one of the rear wheels lifts up getting into my driveway just enough not to grab and I sit their like an idiot haha. If I remember correctly you had a Kaaz unit installed, how do you find it now you've had it for a while? I was looking at getting a 1.5-way Cusco or OS Giken.
I'll keep you advised on the coilovers, mind you freight won't be cheap (Japan to Australia was about $180 last time I bought suspension, I'd imagine to USA would be much more). I'm leaning towards the Cusco Street Zero A's (I've got these on my GS300 and they are fantastic for the street) and adding larger sway bars on both ends... should make for a decent handling car.
Damn, I always forget you're in Australia! That may be more than what it's worth....
So far I love the KAAZ unit for the money. I pulled the diff myself and had a drivetrain shop install the unit itself, and then reinstalled the diff at home. After performing the break in procedure and changing the fluid a few times it performs excellent. I hardly get any noise from it like some users experience (a good break in and a few fluid changes really help this I think), and it's MUCH more enjoyable than the welded diff option. I'm very happy with it overall.
Mortgage Slave
Hello everyone,
I've been away for a very long, it's been four years since last seeing this car as I moved overseas back in 2019.
Anyway, I'm back home now and the car is in a bit of a sorry state. Needs a full service, there are a few rust spots (looks like superficial) and was in dire need of a wash as it sat under a carport the entire time. Should've had a cover over it, not to worry. Needless to say, nothing on it has changed since parking it up pre Covid.
I'm planning to have it on the road again in about a month or so as we've only recently moved back and have a ton of life's stuff to go through (mentally, physically).
Can't believe I'm nearing on *19 years* of ownership with this car! Love it to bits.
The following 2 users liked this post by BLK13X:
Bimmerbill (01-09-24),
KahnBB6 (01-12-24)
BLK13X
Rome was not built in a day so don't rush it. That is when I get I get into trouble. But I will say I am looking forward to seeing it roll again. Good luck.
Bill
Bill
Bill said it best! Go through that bad boy and you'll have it back to its former glory in no time. Looks great - can't believe you've owned it so long!
The following 3 users liked this post by RudysSC:
