The Subtle 2013 NGP GS350 F-Sport Build
#46
#47
Have you gotten pulled over for your tail lights yet? Haha
#48
Any issues with the parking sensors going off with the vinyl on the bumper?
#49
You need to make sure the sensors are wrapped individually. If you use one large piece of vinyl, I guarantee you the sensors will go off. The wrap will eventually lift from cold/hot cycles. So yes, you can wrap the sensors, just make sure you do them individually.
#50
And no, did not get pulled over. Why would I?
#51
Haha, no problem with shrinkage. The key is to apply the tint "cold" as much as possible. The only time you should really use heat is in those fins section to get them to stick and not pop back out. When tint/vinyl shrinks, you've definitely overheated it.
It's illegal to restrict visibility of your tail lights, I'm sure some cops don't care, but if one is having a bad day you might catch a ticket.
I didn't wrap them individually like eddie420 had mentioned, I did it all in one piece, and my parking sensors still work fine.
#52
I did not individually wrap the sensors on my bumper and I have never had an issue.
The people doing Suntek/3M/Xpel are also not individually wrapping them, so it shouldn't be a problem.
#53
It depends what type of film you use (e.g., 3M, Avery, Hexis, etc), makes a difference on whether it will stick or lift up over time. Some films are thicker than others and don't sit well.
#55
I really like how your calipers turned out. Can you go into a little more detail on how you did them? To paint, did you fully remove the calipers, just remove them from the rotor and hang them in the wheel well, or paint them while on the rotors and just cover everything except the caliper? Also, what did your prep look like before painting? How many coats? Did you clear coat over the top? Thanks in advance!
#56
I really like how your calipers turned out. Can you go into a little more detail on how you did them? To paint, did you fully remove the calipers, just remove them from the rotor and hang them in the footwell, or paint them while on the rotors and just cover everything except the caliper? Also, what did your prep look like before painting? How many coats? Did you clear coat over the top? Thanks in advance!
To paint them though, I left them on the car, and covered everything except the caliper
with bags. As for coats, I sprayed on two coats, but didn't let it dry enough before applying
the vinyl, so had to put on a couple more coats to level off the bit the vinyl peeled off.
Yes, I bought a can of clear coat by VHT and used 2 coats of that.
Prep was pretty basic, removed wheels, went at the calipers with a wire brush to remove most of the caked on brake dust and sprayed a generous amount of brake cleaner on all four and some more wire brushing to be sure.
Selahvie (02-06-19)
#57
Thanks, but unfortunately not mine anymore. I sold it at the end of the year
#58
Sorry you sold it, but thank you so much for jumping back in to answer my questions. I'm going to try it this weekend (with the same color VHT paint) if my decals arrive by then and it's warm enough. I recently got an AWD with the same color combo, so I have enjoyed reading through your build thread for inspiration. Thanks again for the help - I really appreciate it.
Selahvie (02-06-19)
#59
Overall they turned out nice. I did not use clearcoat, I wish the copper was more of a metallic penny colored copper or reddish metallic copper as under some lighting and angles it looks more orangish/non metallic. I was thinking of mixing the silver and the copper together to get more of a metallic finish but it was turning more of a dark grey, dark grey metallic would have looked pretty cool though too.
Selahvie (02-06-19)
#60
I am planning the VHT Copper. I picked up two cans and the clear coat at Advance Auto. Good tips on the rears - I can already tell they will be more challenging than the fronts. Thank you for sharing your experience - that will definitely help me. How long would you both recommend waiting between coats?
