My new to me sc300
#31
Some more progress , slow unfortunately lol
Block decked and cleaned up
Cleaned up and undercoated the whole car before lines
Rear sub pre cleaned
Then rear sub after blasting
#32
Nice progress. It helps to have access to tooling through work. When I redid my wheels a few years ago, I used the media blaster at work, and the paint booth. Makes all the difference.
#34
What else are you doing with the engine rebuild??? What sort of rods, rod bolts, and crank are you running? What sort of head gasket? I know if you go NA-T and keep the bottom end stock(ie stock pistions, which you didn't use) you need a thicker headgasket to lower the compression ratio a bit.
#35
#36
Getting closer!
Head cleaned up good!
Oooo studs!
Manifold, turbo and dp fitted
New peices!
1k Bosch injectors
Modded fuel rail fitted
All buttoned up ready to drop in
Oooo studs!
New peices!
1k Bosch injectors
#42
