Build Threads Details on Club Lexus 3IS owner vehicles
specONE Build Thread
Old Oct 27, 2015 | 12:07 AM
  #136
FSportDRM's Avatar
FSportDRM
WOW! That beautiful...... I am going to bite your style with those wheels...what are the specs?
Old Oct 27, 2015 | 09:45 AM
  #137
JCurtis3's Avatar
JCurtis3
AMAZING. THOSE WHEELS.... WOW
Old Oct 27, 2015 | 09:58 AM
  #138
wsabichris's Avatar
wsabichris
oh snap I think I saw yours on Facebook last night. Looking good man! Lets link up, you in SoCal?
Old Oct 29, 2015 | 10:19 AM
  #139
juvi22003's Avatar
juvi22003
Looks nice, what are the specs they look weak....
Old Oct 29, 2015 | 01:44 PM
  #140
specONE's Avatar
specONE
They are weak compared to what you were doing.
some people will consider this aggressive while others say it is not. eye of the beholder i guess.
i'm not into super camber look to make it fit look so this is perfect for me.
specs are as followed,
19x9 +32
19x10 +40
Old Oct 29, 2015 | 01:48 PM
  #141
specONE's Avatar
specONE
thanks
located in NorCal actually.
Old Oct 29, 2015 | 04:28 PM
  #142
jkhang714's Avatar
jkhang714
So cleean. Loving it
Old Oct 29, 2015 | 04:50 PM
  #143
chyeea03's Avatar
chyeea03
Those wheels! Man I'd love to have a set of those on my IS. Is that the sunset/richmond area?
Old Oct 30, 2015 | 10:13 AM
  #144
juvi22003's Avatar
juvi22003
19x9 +32
19x10 +40
Nothing to do with camber, cause i'm not into that i like to be able to drive my car. you have went a lil lower with the specs and just saying this because i was also on bags but either way car and wheels look good !
Old Oct 30, 2015 | 11:04 AM
  #145
specONE's Avatar
specONE
I rather not go any more aggressive.
The rear 245/35r19 tire is already rubbing on one side (driver) bumper, very slightly but makes horrible noise.
Do not understand why one side only and the car has never been in accident obviously.
Going to have Alignment for Toe adjusted to see if it helps if not then I will have to go with the camber arms to induce very slight camber change to get that 1-2mm I need away from the bumper
Old Oct 30, 2015 | 12:53 PM
  #146
ichobu's Avatar
ichobu
no major updates yet.
Worked on removable magnet mount license plate for the front bumper.
The super strong magnets I'm using
it fits perfectly into the OEM plate holder mounting holes
Both pressed into place. License plate will hold them in place and do not even need to glue or tape them down.
Marked on back side of bumper where i will dremel through plastic so that the magnets sit on the actual grill plastic so the magnets will be stronger hold
dremeled through bumper, this part will never be seen that it was cut
Double sided taped and wrapped the magnets so they dont accidentally seperate
taped down
both sides done
Here is video of it working pretty well.
Magnetic license plate mount 3IS - YouTube
wow this is soooo smart. NICE!
Old Oct 30, 2015 | 09:20 PM
  #147
specONE's Avatar
specONE
I take it you also reside in SF?
Close by no, its actually other side of the city. Excelsior mission
Old Oct 30, 2015 | 10:22 PM
  #148
chyeea03's Avatar
chyeea03
I'm from SF, live in SJ on weekdays but back up here on almost every weekend. Keep up the great work, hopefully I'll see you cruising around one day.
Old Nov 15, 2015 | 07:32 PM
  #149
specONE's Avatar
specONE
Lets add to this.
Messed with the ijdmtoys fogs a bit
wanted opaque they mentioned but they didnt have it in production so I decided to emulate the look.
Bought some of this.
came up with this
comparison of with and without film
ran a fog light harness in the vehicle so made a harness plug off the Light side as well so it is easy to remove with it still attached to bumper.
final product
And here is the White LED foglight switch i got from Aliepxress
http://s.click.aliexpress.com/e/QBUJeMB
its a bit bright but i took it apart and modified it a bit to dim the LED down a bit.
fog light switch, color is off when camera flashed but its close enough
LED backlight is white as well. and dims like all other factory switches
video of the switch in action
Here they are done and on the car.
Old Nov 16, 2015 | 09:24 AM
  #150
cp2's Avatar
cp2
Veteran: Air Force
great job, but can you edit what you meant to say right under the comparison pics? I can't make out what you mean? also, what was the reason for removing the back for? couldn't you just add the connector to the wires w/o removing the back cover? if it's okay w/ you, I'd like to get w/ you offline to discuss your work. I want to do the same set up as you, but am need of assistance...aka wiring diagram...haha! thanks and again, great job!
