SC400 project w/6speed from 350z
I purchased one of these that I will be installing in the next few weeks. Collins recommended it, will report once I've been able to try it out.
http://www.summitracing.com/parts/atm-5289/overview/
If someone can figure out a better shifter setup, that would be phenominal. Right now that is the #1 area for improvement in my opinion. I can live with my setup, but it would be huge if there was a better solution.
That's sick man, quick question I don't know if it's been answered or not. What did you do with Trac and Heated Seat switches?
can we idiot prof this set up FLYWHEEL is ? 3vz/5vz or 3sgte or vq35 CLUTCH is sr20 or vq35 PP 3sgte/2ar/2az. ive read tho a few builds and there seams to be a few different ways. im over thinking it i belive.
and lets make 1 for 1uz and 1 for 1/2jz.
please and thank you
wat
ive read a few swaps flywheel from a 4 runner. but the 4 runner came with a 3vz-fe 3.0 and a 5vz-fe 3.4 . ive also seen people use a 3s-gte flywheel aka mr2 turbo. and i saw some one use a 350z flywheel and clutch aka vq35de.
clutch sr20 and vq35de
pressure plate ive seen 3s-gte/mr2 tuebo or scion TC witch has had 2 deifferent engiens the 2ar-fe and the 2az-fe.
so i was hoping to clear the mud and what flywheel what clutch what pressure plate. for both 1uz and 1/2jz swap. most people dont want to read tho 100 pages of swaps with 1j 2j 1uz all mixed together with different setups thats all. im also planing a 1uz cd009 tt setup.
I am 2jz. Right now the two options I know of for the 2jz application are:
1) Collins custom flywheel and clutch setup, designed to just be a bolt on solution. He has a few different stages he offers depending on your HP goals. Requires the bell housing to be milled.
2) Collins flywheel adapter. Bolts to 2jz crank and converts the bolt pattern to a 350z flywheel, so any off the shelf 350z flywheel and clutch setup to be used. Requires a stock auto flex plate to be used as well for starter engagement. Does not require milling of the bell housing.
Hi All,
I just read up on this thread and I would like to add my input. Please feel free to review it, revise it, etc.
This is a running Bill of Materials needed for a CD008 or CD009 6 speed from z33 350z to 1uz sc400.
-CD009 Z33 Trans from 2005+ 350z/g35 $600-$1000
Keep factory engine/bellhousing mounting bolts!
-Collins trans adapter $300
http://collinsadapters.com/index.php...ter-plate.html
Collins trans mount $175
http://collinsadapters.com/index.php...and-mount.html
Collins pilot bearing adaptor $55
http://collinsadapters.com/index.php...g-adapter.html
Collins Clutch Release Bearing adapter $105
Collins 1 piece driveline using slip yoke from nissan titan 4x2, 1350 u joints and 4 bolt flange/saddle $450
Collins Driveshaft to diff adapter $145
Collins Tilton and PowerTrain components Twin disc clutch w/ ARP hardware $1085
Use factory Toyota Auto flex plate
New Toyota pedal assemblies, includes MC and res $469
http://www.driftmotion.com/SC300-SC4...t-p/dm1694.htm
Lexus OEM 5 speed shift console $60
http://www.luxurymods.com/sc300shiftboot.aspx
350z Nissan slave cylinder
SS clutch line $40
What length? What ends?
Speedometer Pickup:
Dakota Digital Speed Interface
SGI-5 ? $85
-------OR---------
Speed Healer
http://www.healtech-electronics.com/products/sh/
-Redline MT-85 fluid
SC430 Diff 3.27 Ratio
So you can definitely get it all done for under $4,000 including shipping/freight and odds/ends/bits/bobs/etc.
I would say closer to $3500, maybe $3000 depending on the price of the transmission/slave/shifter/
Read more: https://www.clublexus.com/forums/per...#ixzz3NPfrYOOz
SS clutch line $40
Speedometer Pickup:
SGI-5 ? $85
-------OR---------
Speed Healer
I know i'm bringing this thread back from the dead and I apologize but how are you guys running the Speedo? I'm really confused with this. The 350z trans does not have a speed sensor right? I was told the speed sensor is located on the diff on 350z please correct me if i'm wrong. I'm trying to get my car's speedo to work again
