Holy 1J!!!
old brake lines
new brake lines
abs taken out
cleaned up the bay in the corner pretty well. these are in process pics guys,,,things will get cleaned up much more
now i need to figure out how to close the up the holes that lead into the cabin. could use some input on that
heres the motor are freshened up ready to drop in. just missing coilpacks, have to modify the 1zz plate so that all my coilpacks face towards the firewall.
interior is back together and looking much more cleaner!
cleaned up a ton of wiring behind the dash and by the footwell. Once i get the car running, im gonna build a cool custom command center on the center console to house my kenwood deck that was in my previous car and mount my wideband. will probably mount more things in there in the future, just have nothing to add to it atm.
here is my abs delete kit. i had some problems with the kit however...the bolts i received were too long. Long story short, i sheared off the head of one of them it resulted in having to buy another brake master cylinder. good thing they're cheap!
The rear brake line was a little short...but i made it work
and heres the bay currently. Im going to run my harness through the gold plated grommet i have there in the middle. the end result of the grommet didnt quite end up as i wanted...but it should work. I ended up covering the other exposed firewall hole with heat reflective tape...hopefully it does an ok job keeping heat out of the cabin. Should be fine...i couldnt imagine much heat traveling to that side. i think most of the heat is going to be concentrated in the middle
currently working on converting my power steering to braided lines and AN fittings. more to come!
I recently blew my head gasket so now that I took my engine out I am sanding it down, putting on bondo, and painting my whole engine bay flat black. what I did with the hole on the a/c thing was epoxy the hole shut so that a/c doesn't leak out of there, and to keep less hot air in. either way though you took yours out so that's not a problem. the biggest problem that I see with your way is that the road noise will go way up. i'm not sure if your worried about that though. lol. but only time will tell.
good luck. love the build by the way.by the way, heres how I did my abs delete mod too. if interested just click on the picture, it'll take you to photobucket and you can see ll my pics.
with work updating their firewall, its made it really hard to update my thread and keep up with the forum. i cant view photobucket pictures anymore so it basically makes going on the forums pointless. Anyways, ive been really busy with the car lately. I finally got the car started and driving! got the car visually ready for the Friday the 13th meet this past weekend
someone snapped a pic with their hi-res camera
car is running exceptionally cool
went to drift and drag on saturday
the night ended on a bad note though because my brakes stopped working :/ air got in the system and i didnt feel safe driving the car home so i left it at a buddies house. had to snap a quick pic of it before i left. took forever to get the car parked in the driveway. living that #lowlife now
hope i didnt overload the page too much lol. theres more updates...but you'll just have to wait and see
So with a new set up, my car is pretty much done. the motor is set up with way i want it and making a good power, my suspension is all solid and complete, and my car looks the way i want it to. only thing thats rly left for me to do with the car is get an FD approved cage on the inside, relocate my battery to the trunk, and a few other small bits. here are a few pics from drifting. first pic was on stock set up. pictures after that were on the new suspension set up
after a few drift events, i found the need to stay planted in my seat so i sold my mk4 seats and bought and fia approved corbeau fixed seat
Its actually REALLY COMFORTABLE. i figured going with a fixed seat would strain my back or something from sitting straight up all the time but i actually find it nice and comfy. i rly dont miss my mk4 seats
i also recently painted my side skirts and rear lip all one color
not too shabby for rattle can. ill have better pics up soon
and heres just some randoms i wanted to throw up. sry for the huge post! thats it for now
