Build Threads Details on Club Lexus IS-F owner vehicles
Sarge IS-F's re-build Thread
Old Dec 3, 2011 | 10:37 PM
  #91
RX7 RAGE's Avatar
RX7 RAGE
nice thread dude
Old Dec 3, 2011 | 11:42 PM
  #92
CalitriSC's Avatar
CalitriSC
did you get the door sills on? just wondering if your car was already pre-wired. I got a set too that i haven't put on the car yet.
Old Dec 4, 2011 | 08:40 AM
  #93
SargeISF's Avatar
SargeISF
No, the car wasnt pre-wired. Here are the wires I used. I didnt take picks of the install, but its pretty straight forward.
What you need:
16-14 gauge wire (approx 10ft per side)
T-Taps.
Take the B pillars, and the factory sills off. Behind each B pillar is a Blue Plate covering a connector with some wires.
On the Driver side, run a positive wire from the thick black wire on the connector, and a negative to the single pink wire. (its pretty stiff, and is attached to a plastic "L" bracket)
On the passenger side, run a positive into the same looking connector under the same looking blue cover, and tap into the top Green/Red wire (its thick and on the top of the connector). Then tap the negative into the same pink wire like you did in the driver side.
Here are pics of the finished product.
Old Dec 4, 2011 | 08:49 AM
  #94
SargeISF's Avatar
SargeISF
Looks like there is allot of room inside of the door lights. I was thinking of getting a nice size SMD LED's in there. This way I can get them in blue, and they can produce the same amount of light the white ones do.
Here is what Im looking at.
Looks like I can modify the bracket inside of the housing, and remove the heat shield to make it work. More to come.
Old Dec 5, 2011 | 07:49 PM
  #95
Silver10's Avatar
Silver10
Very nice Resurrection of a once neglected F
Old Dec 8, 2011 | 09:35 AM
  #96
hwy1isf's Avatar
hwy1isf
Sarge, did you install the Black Volks, and can you post some picks if you have or when you do?
Thanks
Old Dec 8, 2011 | 11:33 AM
  #97
sushiboi's Avatar
sushiboi
^He sold those I believe. Too much work to make those offsets work with the F.
Old Dec 8, 2011 | 01:47 PM
  #98
Stylnhonda's Avatar
Stylnhonda
Nice! Hard to believe the car has that many miles on it.
Old Dec 8, 2011 | 04:31 PM
  #99
SargeISF's Avatar
SargeISF
Thanks
^^ correct sir! I dont think flaring fenders on an F over 1" would be a good idea.
Old Dec 8, 2011 | 04:37 PM
  #100
SargeISF's Avatar
SargeISF
Update 12/8/2011
Well guys I have good news. The large wedge led fits!!!! And it is bright as hell!
Before.
The Clears and the new LED from SBLED's.
Clear cover removed (inside), and LED in place. You dont need the heat shield. The leds are cool.
Installed on the door.
Old Dec 8, 2011 | 05:31 PM
  #101
SargeISF's Avatar
SargeISF
Next up: Clean up the shiny, dirty steering wheel. This thing shines so bad, it reflects the sun,lol.
Im going to use the advice on this thread to help out.
http://www.autopia.org/forum/car-det...ing-wheel.html
My wheel is bad, so I will be using the magic eraser with the 7.7 cleaner. More info to come!
Old Dec 16, 2011 | 02:56 AM
  #102
SargeISF's Avatar
SargeISF
Well, looks like Ill clean this steering wheel up to sell!!
I just ordered a silver carbon one from Sewell with some new matts. Interior will be completely restored! Also, just found out the shift **** on these cars is an M10 1.25., so I think Im going to invest in one of these babies to get some accent touches inside. The black stock shift **** looks cheap compared to the rest of the vehicle interior.
Pics of wheel and install soon! Here it is on Sewell's site.
Old Dec 16, 2011 | 06:06 AM
  #103
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
Looking good Sarge.. Nice mods....
Old Dec 17, 2011 | 07:04 AM
  #104
ISFSteve's Avatar
ISFSteve
I have this steering wheel and you will love it. Much better feel and slightly larger in diameter. I also have this **** but with the F etched on the top.
Old Dec 17, 2011 | 07:36 AM
  #105
SargeISF's Avatar
SargeISF
Steve, where did you get the **** at? Can you PM me some pics of the interior?
