Build Threads Details on Club Lexus LS400 owner vehicles
Vincent123; ucf21 build
Old Sep 29, 2011 | 05:27 PM
  #346
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
i like the idea but why 3/8" that's pretty beefy for just a cover.
....can i trace your template onto some cardboard one of these days and try making one out of a thinner gauge alum? please?
Old Sep 29, 2011 | 05:39 PM
  #347
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
nice Vin! well 3/8s is good cause it will actually take the beating. if u use thinner aluminum then itll just tear right through. pretty sure he thought of that before and dunno why u didnt.
  #348
Vincent123's Avatar
Vincent123
lol 3/8 to protect the oil pan. I would take it off and let you trace it but instead of re-using the factory screws that held on the plastic guard in the front I replaced it with a bolt / nut and its a btch to put it back on
Unless you want to trace it while its still on the car, that would work if we have access to a lift
Old Sep 29, 2011 | 05:40 PM
  #349
Vincent123's Avatar
Vincent123
I originally wanted to use stainless steel but when I went to go buy one my wallet disapproved
Old Sep 29, 2011 | 07:03 PM
  #350
sgv_bum's Avatar
sgv_bum
looking good ...
  #351
Maxx941's Avatar
Maxx941
That's an awesome and smart idea
Can't wait to see the trunk finished
Old Sep 30, 2011 | 03:33 AM
  #352
Vincent123's Avatar
Vincent123
trunk is going to take awhile, I'm in the process of getting all my new suspension pieces dialed in first before I finish up the trunk
Gotta install my poly bushings too =\
Old Oct 3, 2011 | 04:25 PM
  #353
Vincent123's Avatar
Vincent123
I got some parts in today! Adus polyurethane bushings for front strut rod, rear trailing arm, and rear axle carrier. Stoptech rear stainless lines and new front lower ball joints. Gonna get custom front stainless lines made by lextreme on thursday, couldnt find anyone that made it for my year
Old Oct 3, 2011 | 05:31 PM
  #354
shajbot's Avatar
shajbot
Awesome build Vincent, may I ask where did you get those bushing at? And would you know the part number for UCF10 (1993)?
Old Oct 3, 2011 | 05:58 PM
  #355
Vincent123's Avatar
Vincent123
Got them from here, talk to Jerry
http://stores.autowearhouse.biz/-str...Categories.bok
Old Oct 3, 2011 | 07:06 PM
  #356
PureDrifter
BahHumBug
CL Folding 100,000
good luck with the ADUS front strut rod bushings, Hope you have better luck with them than i did.
i've got a new pair of OEM bushings waiting for when i rebuild my front susp to swap out the old ADUS.
Old Oct 3, 2011 | 07:25 PM
  #357
Vincent123's Avatar
Vincent123
What was wrong with your adus bushings? If its stiff I dont really mind that, i'm going with 26k spring rates anyway
Old Oct 3, 2011 | 08:13 PM
  #358
PureDrifter
BahHumBug
CL Folding 100,000
the ride was a little rough but not too bad at all, the bigger problem is that because the bushing is a hard poly compound the damn things squeak CONSTANTLY. i tried both silicone-based spray lube and moly/teglon grease and none of them quieted it down.
couple other members had similar issues, and since you can now get the OEM Rubber bushings from lexus for ~$35-45 each there isn't much point to the ADUS imho. (when i got adus back in the day there was no oem option short of buying new bars)
Old Oct 3, 2011 | 08:15 PM
  #359
Vincent123's Avatar
Vincent123
when i placed the order, they included some prothane bushing grease. Not sure if I should use that brand of grease though. I did a search and ppl were saying good things about the motul tech grease 300
Old Oct 3, 2011 | 10:35 PM
  #360
PureDrifter
BahHumBug
CL Folding 100,000
i had used that when the bushings where installed into the arms.
didn't do much after a month or so.
what you could try if you're dead set on using them is having the bars drilled and modded for a zerk fitting, and grease them time to time.
