SC570--The OFFICIAL build thread
#451
Did a quick test fit of the turbo on the driver side a few days ago, and cause of the fuse box and the radiator and fans, it didnt fit so good. So, got to moving the fuse box, tilted the radiator forward a bit, and started to rewire the entire car. Finishing it up today, so more pictures this afternoon. But for now, the initial test fit, and a pic of the car in progress: (excuse the cell phone pics)
Yes, the harness is back in the fender. But down to about 11 wires total. Airbag wiring will come out once the new steering wheel setup is installed:
#454
It's all love lol I went for a ride in a buddies 600hp all motor vette and I give your props for having the ***** to strap a big *** turbo to that bad boy.. How much you plan to make?
#455
Lol, had to ask. So hard to "read" emotion through text.
Right now plan is to hit the 700rwhp range on low boost with water/meth, cam, and tune on pump gas. Not too worried about the engine as it only has 58k miles on it, but if it does pop, I will be swapping to an LQ4 block. But there is a fellow LS1 owner on LS1tech that put down 779rwhp on a stock block/head with the same turbo @ 17.3psi, and IIRC he has just a tad over 100k miles.
#457
Finally got around to taking a couple non-cell phone pics today, and being shaky as I am, they still came out kind of .. One thing I didnt get a picture of is the rear of the car with the bumper cut and spare tire-well removed. But here are a couple showing a bit more detail on the car. Its still dirty, so excuse the mess.
So this last week, was all preparation for the turbo. Moving the fuse box behind the drivers seat, look closely and you can see its tilted forward about 2'' or so and I still need to make new brackets. Aside from that, ALL the sound dampening material from inside the car is finally gone, and with the 3'' dumped exhaust, I have managed to toss every bit of luxury out the window.
More to come soon, along with a new steering wheel setup, and actually get around to finishing the cage. As for the turbo, its going to be a few months before everything is ready, cost of the TRD diff is going to kill me and slow everything down.
#459
At first it was enough to make me nervous, but other than that I cant really feel a difference. Just have to be more attentive when slowing down, and turns are a bit slower, but I drive normal. The rears are a 5.5'' backspace, fronts are 1.75'' back space and needed a 25mm spacer to clear the calipers, but they fit good enough for what the car is being used for.
#462
I had a feeling you would push for the turbo lol.
But I have good reason for wanting to ditch the lag from the BW, and upping compression slightly:
^^While that isnt supercharged, and its an all motor LS3 stroker, I love the response in power and know that even with the cam, the turbo is going to hold my power-band back a little to the higher range. Hence I was considering the V2, which I can get cheap to the point I wont even say how much.
So frustrating...stupid LSx engines, make choices so difficult.
#464
Chris- Turbo setup on the LSx is the **** make load of power , and still spools that turbo like it was a 58mm turbo on the 2jz!!.
I am building on LY6 block 6.0, rods, pistons, and upgraded Valvetrain on LS3 heads since the LY6 comes with LS3 heads from the factory.
Those engines looooooooooves boost (turbo) .
I was thinking about using my 74mm (gt4202) with the biggest a/r I could find but My tuner told me to go with the 80-88 to make some power since i am going with a built motor.
I spend 10days searching on LSx forums and yeah i need a 80mm to make 1kwhp and it won't have no problem spooling that thing.
You have the right Turbo for that engine and setup S475 it is.
2jz makes 850-900whp on gt4202 when the LSx makes 770 -780 max and hondas make 1000-1100hp with that turbo.
So that 475 is perfect.
Turbo sounds better and you can control the boost better.
But either setup will be great as long as it's not staying NA lol .
#465
Hey man. Great build. Your thread is one inspiration of my decision to build an LS SC. I have read the entire thread but cannot see where you mentioned to decide to dump the stock gauges. I am assuming you got rid of the ac to reduce your weight and parasitic power loss as the SC is now more of a competition vehicle. Also, when the ac was in the car did you convert to dedicated switches to get it operational?
Thanks
Thanks
