My ´97 SC400
#107
Hy!
@NEbiker10..this are Borla tips. i think, this here the type link in 2,5"
Today, the tips are welded and all painted
hang up
tips with tape and paper masked..
and 2 layers coating
After 3 hours, i fitted back on the SC
ready!
and a video B)
http://www.youtube.com/watch?v=bOtWKrPz9bY
maybe next week, i will pick up the licence plates and do a test drive
greets
Boergsn
hang up
ready!
and a video B)
greets
Boergsn
#109
Today, i installed the Cable for the new amplifier in the trunk
Is this a sensor for the alarm-system?
oh! what is this? in the back of the inner fender
pre-clean
better
...in the car
removed the rear parts to come with the cable in the trunk
on the subwoofer cover is the parking speaker... good to remvoe its too loud!
original speakers
next steps are the adapter plates for the 6,5" coax System and the subwoofer.
greets
Boergsn
pre-clean
better
...in the car
original speakers
greets
Boergsn
#111
So..next steps are done
My first idea, to install the Hertz 16,5cm coax system are failed. The chassis was too big for the small hole in the back. Here the pictures. I build a seperate adapter plate to fit the speaker, maybe is possible with weaker 16,5cm speaker with a smaller chassis and magnet.
ok... i modified the oem adapter to fit 13cm speaker:
ok, its very easy possible, small modifications for install
Today, i arrived the Phonocar Speaker:
and installed this:
fits for me perfect The sound is good
#113
HY!
Today, i installed the Boston Woofer
As first, i removed the plastic ring over the chassis, is very easy with a screwdriver
next step was to remove the membran from the chassis
next
done!
After this, i tested the adapter with the woofer in the car, if its all ok (terminal, enough space around the woofer....) and all ok, i marked the holes for the screws and drilled the holes and maked a M5 thread for the screws in the alloy
the holes are all ok, and i mounted the foam rubber and the connector with cable
yet, i fitted the woofer on the adapter, fits perfect
wiring with protection
One point was for me important, the new woofer + foam rubber are not higher as original
installed in the SC
The sound is much better, deeper, clearer, with more precision, not only deep tones, but the woofer need much more power as the oem part. Next step is to mount some bitumenplates and install the old Sony Class A amps
greets
Boergsn
next
done!
installed in the SC
greets
Boergsn
#116
Thanks!
Today, i installed the new speaker in the front doors. with a small adapterplate was easy to install the 13cm speaker. The sound much better i´m happy
Door and more:
speaker removing
nice...a seperate closed housing for the woofer
but the 13cm don´t fit
I cutted a 5mm plate to a adapter, modified the box and mounted the speaker. on the speaker, i cutted the original mounting points and drilled holes to fit.
it´s not a highlight, but functional i modified also the grill on the rear side
Sounds better, more dynamic
greets
Boergsn
Door and more:
speaker removing
greets
Boergsn
#117
HY!
Yesterday, i cleaned my summer tyres
These are IS250 Sport wheels with 235/40 and 245/40 Continental 3
245er on 8,5
235er on 8
also, i installed hidden valves, looks much better
In the car, i mounted bituminous mats, but i need more
The grill fits perfect
The 2,5" gaskets are coming for the IMF headers
Today, i modified the suspension again. first was the supra/Bilstein suspension.
But i´m not happy with this, also get modify
245er on 8,5
235er on 8
#118
at first.. mounting place
ok,lets go!
i mixed the parts: Rear Suspension: Supra Bilstein damper, Kayaba Supra TT spring, SC400 support and Supra stopper.
The SC400 and the Supra stopper are different
with double sided tape its easy to fix the stopper
spring teaching
The oem SC spring is complete others, the Supra/Bilstein is a little bit smaller as the Kayaba TT.
all parts united
rear suspension done
the rear is higher...mh.... ok....go to the front suspension.
The front suspension is also Supra/Bilstein but the spring plate are 18mm lowered.
Spring teaching
The SC spring are more massive and higher
first side done on front
and rear
The driver side also modified
done!
The car feels like more stiffer, but not hard, more balanced i think.
Maybe was the supra/bilstein suspension from a NA Supra? does no matter, the suspension is modified
greets
Boergsn
ok,lets go!
spring teaching
all parts united
Spring teaching
and rear
done!
greets
Boergsn
