Build Threads Details on Club Lexus 2GS owner vehicles
GS 400 cams and exhaust headers
Old May 24, 2026 | 06:41 PM
3boysdad's Avatar
3boysdad
4th Gear
Default GS 400 cams and exhaust headers
Anybody done this ? Installing Kelford 208-B. Most gains and still street drivable.
p
will work without tune…. But leaving HP on the table….
anybody know a piggyback solution or shop that can program a full ECU… would love to ditch CAT’s in process.
Old May 25, 2026 | 04:28 AM
TrueGS300's Avatar
TrueGS300
I don't think there are any tuning devices that work with modern Toyota ECUs. Other than full stand alone. From what I hear, the factory ECU fights and changes air/fuel ratio settings back when using piggy back units. I like the idea of a mild cam swap. ECU won't know the difference, the MAF will just tell it to fuel more for the extra incoming air.
Old May 25, 2026 | 06:58 AM
dwoods801's Avatar
dwoods801
The best option is an Apex’i NEO, make sure to get the one for a V8, they discontinued these about a year ago, but u coat still find them, and there is a whole thread in the “How To” section with instructions for how to wire up to your car. It’ll be a great for adjusting the timing and AFR to accommodate the Cams and Headers, I would love to get some cams in mine, and some forged pistons with a 12:1 compression ratio, get the most of an N/A engine.
Old May 25, 2026 | 02:17 PM
3boysdad's Avatar
3boysdad
4th Gear
Default 74 ft lbs torque
I purchased a rear end from a GS 300 which is 3.96 and is a huge improvement over stock 3.26….
a mechanical advantage of about 74 ft lbs of torque.!!
now…. At 80 on hwy it does sit at 3000 rpm.
Old May 26, 2026 | 07:27 PM
TrueGS300's Avatar
TrueGS300
It's funny, I did just the opposite. I put a GS400s 3.26 ring & pinon in my GS300 to bring the rpm down and to have longer gears before having to shift. (I am manual swapped and turbo though). As your power increases you outgrow lower (numerically higher) gear ratios.
Old May 26, 2026 | 08:07 PM
3boysdad's Avatar
3boysdad
4th Gear
Default Manual swap
That’s cool…. What kind of numbers did you end up with ? Thinking I wanna do a supercharger.
when my trans gives out….254k and counting.
It’s been treated well, with oil changed every 30-40k… But I drive like a mad man in the TN mountains daily. 2300 ft of climbing everyday. Lots of turns.
ill do a manual swap !! and need all the help I can get.😜
Old May 27, 2026 | 05:25 AM
TrueGS300's Avatar
TrueGS300
I have a build thread you can check out if you want. Some good V8 build threads too. My Manual swap is pretty detailed.
Lawzndr
GS F (2016-present)
13
Apr 26, 2018 05:58 PM
Toddski
Performance
Mar 21, 2018 03:56 PM
B00M3R
Feb 27, 2017 07:44 PM
rmillsISF
IS F (2008-2014)
May 8, 2016 06:41 AM
AdamLexus
Jan 26, 2008 09:19 AM
