How often do you wash and wax your car? + clear bra
It seems I am getting lazier and lazier lately. As long as the car looks okay, I don't feel like washing. lol I used to wash it at least twice a month. A friend of mine washes his RCF once every week.
I wonder how often you guys wash and wax your car? I need some motivation.
Also, any tips on how to wash cars with clear bra? This is my first car with clear bra done. I was told I gotta at least use spray wax every 2-3 washes.
You can wash and wax it as often as you'd like.
You should be able to wash a car with clear bra the same way as one without. Why not use spray wax on every wash, there are spray waxes that can be used wet or dry to save time. Be aware that most synthetic sealants will outlast carnauba paste wax and spray wax.
Not sure if your referring to the black car but Im sure many will tell you that keeping black car clean is a full time job, but one of the most rewarding colors if done right imo...
If I was in your shoes I would wash the car, inspect paint to see what it needs, are there contaminates that need to be removed if so get one of those off the shelf consumer clay from meguiars and decon the paint/bra, then you can use an alcohol wipe down to remove any residue and ensure a the synthetic sealant will bond properly. This will make your life going forward easier and it will be easier to maintain as the sealant will be a strong form of protection then you can wash and wax with spray wax and reapply sealant in lieu of spray wax as often as you'd like...
Once its all done, take a step back and enjoy the work you just put in! Of course the real option would be to polish after the claying step, however most cant even maintain the above so use what works best for you in your scenario.
Edit** when and if you clay be alert of the edges not sure if you may encounter this however when you clay around the edges clay tends to stick around the edges and leave pieces of it behind. Can be time consuming to remove too.
Ahhadanny (07-13-17)
Auto Detailing Master
I wash my car every week... if I am busy it may get pushed back to 2 weeks, but not usually.
Washing a car with clear bra is the exact same as washing one without.
How to Properly Wash & Dry A Car
It is never a bad idea to apply some additional protection on top of a clear bra, however spray wax is not the only option. As K20trick mentioned, a spray wax can be a great option to use after every car wash to help with drying. Spray waxes are not very durable, and therefore should not be your stand alone means of protection IMO. Apply a quality paint sealant or nano coating to the entire vehicle, including the clear bra, in order to provide more durable protection. Then use a spray wax frequently to maintain the protection.
If you decide to use a polymer sealant like Blackfire Wet Diamond, plan on reapplying to the entire vehicle every 4-6 months on average. If you opt for a nano coating, you can go several years without needing to reapply. There is plenty of information on nano coatings in the stick thread in this forum.
-Zach
-Zach
My washing schedule has always been based on need and the function of the vehicle. Functional cars (vans, trucks, or anything that requires a ladder for me to clean the roof) get washed once a month. Daily drivers are once a week/two weeks if it's only dusty. Garaged cars are whenever necessary and/or before going to a car event.
I've found touchless silica sealants (Carpro Hydro2, Nanolex wash coat, Gyeon wet coat) the easiest to work with since its a spray on rinse off type of product. The only requirement is that the paint has to be cool to the touch and in the shade to avoid streaking.
Gyeon cure is also a really nice spray sealant that can be applied wet or dry. Any of these combined with a leaf blower or metro blaster will make your car washing process a lot faster.
So to answer the question of how often to wax, never. Detail the car and apply a nano coating, or pay someone with experience to do it.
Ahhadanny (07-15-17)
Ideally every 2 weeks. But sometimes, when I'm bored/free, I'll do it weekly.
I wash and spray wax to dry every time I do my wash. For interior, I try to detail in between washes. But, I do it as needed; I keep my inside pretty clean overall.
I use Meg's UQW during my drying process. Leaves a nice glossy surface. The water beads are awesome as well as contaminants like bugs, pollen, bee sht don't stick as hard.
Ahhadanny (07-14-17)
What time of the day do you wash your car since it's sunny and kinda hot almost all day long in the summer?
I love it! It does a great job of repelling dirt and water plus it gives the car a nice glossy/wet look when it's nice and clean. I also ceramic coated my new wheels as well to repel brake dust and grime. I had some tar stuck to the inside of the barrel of my wheels and it came off easily with some TarX remover. The best part is not having to wax the car since the ceramic coating has UV protection. I usually wash my car late in the evening at 7 pm, which gives me about 90 minutes before it gets completely dark.
One neighbor told me I was going to wash the paint off my cars. That pretty much says how often I wash my cars. Probably about three times a week. Clay twice a year. Apply a sealant twice a year. Once a month I pull the wheels so I can make sure I get them totally clean. It also gives me the opportunity to clean everything behind the wheel.
