Does Zaino Expire?
Does Zaino Expire?
Good Day
I bought a zaino kit several years ago and never got around to using it after reading the instructions and figuring that it would take a full day to a day and a half to go thru all the steps.
Fast forward to today and I am now inspired to finally use it. Does anyone know if the zaino products degrade over time or expire? Thoughts?
Thanks
Thanks
Yes, I believe each product does have an expiration date. Check the website, I think I found it there, otherwise send them an email and Sal will respond and give you the specifics.
pretty sure it does go bad. I end up using it all year and taking a break in the summer and I will usually toss what left and order an fresh bottle.
I've been using Zaino for over 14 years.
Great stuff.
: What is the usable shelf life of Zaino products?
A: A 70° room temperature is best for the longevity of Zaino products. Due to the optical additives used, extreme heat or cold can result in a decrease in gloss-enhancing properties.
When stored at average room temperature between 65° and 75° degrees, shelf life is as follows:
Z-PC 3+ years
Z-AIO 3+ years
Z-CS 5+ years
Z-1 For optimum results, use before 3 years.
Z-2 For optimum results, use before 3 years.
Z-3 For optimum results, use before 3 years.
Z-5 For optimum results, use before 3 years.
Z-6 5+ years
Z-7 5+ years
Z-8 5+ years
Z-9 5+ years
Z-10 For optimum results, use before 2 years.
Z-12 For optimum results, use before 2 years.
Z-14 For optimum results, use before 2 years.
Z-16 3 to 5 years
Z-18 5 years +
ZFX For optimum results, keep tightly capped, avoiding moisture. Use before 24 months.
Great stuff.
Z-PC 3+ years
Z-AIO 3+ years
Z-CS 5+ years
Z-6 5+ years
Z-7 5+ years
Z-8 5+ years
Z-9 5+ years
Z-16 3 to 5 years
Z-18 5 years +
