Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
water stain on lips
Old 08-04-11, 03:21 AM
  #31
NZLou
NZLou's Avatar
Its kind of hard conveying what I mean in words.
I shall try and find the walkthrough I used in the morning if I remember.
Also something to note, by the photos it looks like you only sanded the patch that had the stain? That part of the wheel will always look slightly different now due to it not having clear coat on it.
As for having to sand after stripping, why? All the wheels I've seen have the lip polished and then clear coated for easy maintenance as said before. The surface would only need a buff up after stripping I would of thought.
Old 08-04-11, 10:59 AM
  #32
JDMStanced
JDMStanced's Avatar
i tried to cover all the lips but it was hard to do so near spokes area.
If the polishing process was so easy like apply paint strip then buff, people wouldn't say that polishing is PITA haha
Old 08-04-11, 05:00 PM
  #33
ashtray
ashtray's Avatar
Has anybody tried Scrubbing Bubbles? Like for the shower??
Old 08-04-11, 06:07 PM
  #34
1J0Z SC
1J0Z SC's Avatar
^ NO.....
For wheels only use water and soap, no weird acids or anything...
Old 08-05-11, 09:58 PM
  #35
NZLou
NZLou's Avatar
Haha. Come to think of it you're probably right there.
And yeah, your spokes get in the way a bit. I guess you'll just have to sit there and keep at it. From what I read (And I'm currently in the process of refinishing the lips on my SSR Vienna's) It it possible to get them totaly scratch free. You just have to take your time and not go through the steps too fast.
Good luck, I hope you get them looking like they were.
Old 08-06-11, 12:47 AM
  #36
JDMStanced
JDMStanced's Avatar
can you answer this question? Should i re wet sand with 2000 grit or go back to 1300 grit then 2000 grit?
i'll make sure to post pics when i'm done.
thanks
Old 08-10-11, 11:37 PM
  #37
NZLou
NZLou's Avatar
I've been told that wet sanding isnt the best way to do it. Reason being, it makes the scratches harder to see.
If there are still scratches you will need to go down as far as it takes to get rid of them.
What I'm trying to say is to start low. When you go on to the next make sure that you have none of the scratches from the previous grit left over. Keep working your way up making sure to get the previous scratches out before you more up.
I would be going back to at least 1300 and not using water.
Old 08-17-11, 12:38 PM
  #38
embolism
embolism's Avatar
i dunno, without using water to flush away the stuff you are sanding off, your paper will gum up, expecially as you go finer and finer...
jonmanch
05-23-16 04:32 PM
lexus-is2
02-02-11 03:21 PM
mwaull
08-24-07 09:29 AM
knuckles
07-14-06 11:42 AM
newyorksc
Wheels, Tires & Brakes Forum
03-22-05 01:18 PM
Quick Reply: water stain on lips
