Water Spots
Water Spots
I have a black IS250 and after a nice wash, I clayed the hood because I noticed it has water spot stains.
I clayed it twice and the spots are still there?!?! What's the best way to remove these things? I am trying to achieve a deep gloss black look but the water stain is just horrible.
Any advice is helpful.
A mild polish like einszett Paint Polish or Menzerna Super Finish should do the trick. The einszett can be applied by hand/machine...Menzerna needs to be applied by machine.
http://www.glisteningperfectionstore...00mL%2C/Detail
http://www.glisteningperfectionstore...32oz%2C/Detail
When you mean set it, just leave the damp cloth on a portion of the hood? No rubbing or anything? After letting it sit, what do I do next? Clay it again?
If it hasn't come off with what you have tried I would try the Chemical Guys Water Spot Remover or you will have to start polishing the surface. If you polish start with a light polish and use more aggressive ones as needed. Let me know if you have any other questions!
I had the same thing on my black IS, it was bad and most noticeable on the chrome lining and side windows. I went to the dealership and they said it was from acid rain and I needed an acid rain wash. I asked another friend on his opinion and he gave me a bottle of autoglym. I applied it on a sponge and scrubbed out most of the spots off the chrome. For the windows, it was so bad I had to use steel wool (ones you use to clean pots and pans) to get the spots out. I haven't got to the body yet since I ran out of the solution.
Let me know how the vinegar works for you...
