Best Clay Bar
Dysfunctional Veteran
meguiars is the only one i use. not because im overly brand loyal, but because its just usually the one i see first. i tried it, and it works so why change?
If you make a trip to canada, order from Eshine and they can get you some. They cant deliver Riccardo clay to the US though. They will cancel your order if you try.
I've used most of the major clay kits and they all work pretty much the same. Given that they all seem about the same in performance, I prefer the Meguiar's Smooth Surface Clay Kit. The reason... besides the two 50 gm bars of clay and a plastic storage box to keep them in, a bottle of quick detailer lube, it also comes with a very high quality "Supreme Shine" Microfiber towel. None of the other give you a MF.
Some clay tips:
Clay the paint when it is cool to the touch. Use plenty of lube and gently slide the clay back and forth over the paint in a 2'x2' section at a time. The clay should mostly hydroplane over the surface and it will grab and pull off any bonded contaminants that stick up over the paint surface. Turn and kneed the clay often as it gets dirty. Start with the horizntal surfaces as they will contain the most contaminants. Draw your fingers gently over the freshly clayed surface to see that you have removed all the contaminants then wipe up the section with your MF and continue on.
If you are leaving clay streaks on the paint you are either working on a paint surface that is too warm or you are using too much pressure.
After you finish claying the paint move on to the glass. Clay will clean up the glass really well. It is especially good at removing windshield road grime. Once you finish claying the glass use the clay on your wheels. Toss the clay bar after you finish with the wheels as you don't want to put that back on the paint again.
If, during the process, you drop the clay bar and it hits the ground, toss it as it will be contaminated and will scratch your paint. Grab another piece and continue.
If you are using some one else's clay kit cut the original bar into two or three pieces before you start. Put the unused piece(s) into a baggie. That way you'll have a spare piece to fall back on if (when) you drop a piece of clay.
You don't need to be too **** about wiping up the quik detailer residue as you are going to be polishing and waxing afterwards anyway.
Some clay tips:
^^^Thank You Jim! Your words of wisdom will come in handy.
Tonight I am going to wash my car (of course keep it parked in the garage afterwards). Then tomorrow morning (when it's still cool outside), I am going to clay my waterspot areas on my hood and try it out on my glass too. Not sure about using it on my wheels (I am pretty **** about wiping off the brake dust and applying wax every 3 mos).
Update: I used Clay Magic on my hood, and it worked very well. I washed my car last night, and the water spots disappeared a little more, but some where still visible. I clayed those areas this morning, and it worked! No more more water spots on my hood.
P.S. I'm addicted to using that quick detailer stuff.
