Help! Really Wet Car Mat!
So anyways long story short I got about one gallon of water poured onto one car mat. A little water got off of the car mat and on to the floor but i got most of it up with a towel and its dried now. I have had my car mat sitting outside in the Texas heat (and humidity ) for about 2 days, and now it is dry, but it doesnt look or feel right. Wherever the water was is now discolored and if i run my hand over the colored part its all rough feeling. Anyone know how I can fix this?
Have you tried to brush it in different directins, find the "grain"
And then brush it all that way or exactly the opposite of that way? This usually helps get the carpet all even again. Sometimes a really good vacuum will do the same thing. What color is the mat ?
DanF
DanF
JB
Assuming it was plain old water my guess is the staining is from ground-in dirt already in the floor mat. Soak something that's already dirty and let it air-dry, and you'll undoubtedly have stains.
the staining part is strange if it was just straight clean water but the roughness can be gotten rid of by brushing it back and forth with a stiff brush. same thing would happen in you took a bath towel, soaked it in water and hung it in the sun to dry, you would have a rough feeling towel - that will go away with the brushing and on its own.
as another said, maybe the discoloration is just dirt that worked its way out of the mat and onto the top of the mat fibers.
Nick@Autogeek
Automotive Care & Detailing
04-02-11 07:22 AM
