Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Does a cutting pad make that much difference?
Old Apr 17, 2005 | 12:34 AM
RRocket's Avatar
RRocket
Default Does a cutting pad make that much difference?
Just got my Porter Cable. Tried a couple of small areas to remove sworls with the general purpose white pad..and it didn't do much at all. Does the yellow or orange cutting pad really make that much of a difference??
Old Apr 17, 2005 | 08:14 AM
Guitarman's Avatar
Guitarman
Ron, You will notice a difference between pads yes. Whether it's enough of a difference to solve your particular paint issues is less certain. You *may* need a rotary buffer if it involves cutting or leveling paint or serious spider webbing, but more than likely you'll be able to do it with the P/C, it'll just take longer and require some pad/polish experimentation.
Step up to the next more aggressive pad and work it longer and I'm sure you'll note a difference. Remember though, once they load up with polish (any pad) they need to be spurred now & then because that alone will reduce their effectiveness.
Old Apr 17, 2005 | 02:04 PM
RRocket's Avatar
RRocket
Where do you get a "spur" and what does it look like? Thanks...
Old Apr 17, 2005 | 04:56 PM
ssultan's Avatar
ssultan
Guitarman I noticed it this weekend. Was using an orange sonus pad with Megs #82 and the pad became ineffective after a while...I did notice that it was caked and loaded...was wondering if I should wash and continue...
Old Apr 17, 2005 | 05:55 PM
Guitarman's Avatar
Guitarman
OK, this thread I wrote last year has some info on this subject,
https://www.clublexus.com/forums/sho...d.php?t=131273
But here is the essential paragraph from the 'Definitions' part of the thread;
Spur; A spur is a metal tool that is used to remove compound and polish build up on a pad, Once the pad becomes loaded up with polish, it becomes less and less effective, so "spurring" the pad is necessary a few times during buffing. To do this, you hold the machine against your knee or lap, pad side down, and trigger the throttle button on and off while holding the spurring tool against the pad and moving the tool back and forth over the pad. This dislodges the caked up compound from the pad. This only works on wool type pads, not foam. A Phillips head screwdriver will substitute for a pad spurring tool in a pinch. On foam, you spur the pad by using a stiff nylon brush (a toothbrush will work) in the same way.
The important part is that you DON'T want to use a metal spurring tool (or screwdriver) on a FOAM pad, only a wool or wool blended use those A stiff nylon toothbrush or similar is perfect for foam pads. When raked acrosss the pad with the tool spinning on and off, the bristles will doslodge some of the built up polish. Bear in mind however, that it's a bit more effective with a rotary buffer and foam pads than an orbital, simply because the orbital kind of wobbles and vibrates rather than maintains a certain strict rotation. But it will still help free up some of the cells in the pad .
Beyond that, you will find it necessary to stock up with at least 3 pads of each degree of aggressiveness, i.e. 3 cutting pads, 3 polishing pads, 3 finishing pads. This along with the spurring effect will give you the best performance when doing a multi-step polishing routine. When one pad loses it's performance even after spurring, you'll have another there at the ready. Cheers guys.
Old Apr 17, 2005 | 05:59 PM
Guitarman's Avatar
Guitarman
If you want a really purpose made tool for BOTH wool & foam, here's the ticket; http://www.superiorcarcare.net/spur100.html
Other wise just use a nylon brush. I would stay away from wicker bristled and other natural brushes because they can break off and can stick in the pad, sometimes too small to see, and then you have worse problems when you start buffing again. I've never had issues with toothbrushes in that respect.
Look here at step 2B to see a traditional metal spur tool, being used on a rotary buffer & wool pad.
http://www.automagic.biz/Training/Compounding.htm
Hayk
Jul 13, 2010 06:26 AM
Angelo
Dec 6, 2009 11:09 PM
detailersdomain
Apr 5, 2009 05:30 PM
drck1000
Mar 20, 2006 10:47 AM
