Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Tarnish like pattern on wheels..
Old Mar 18, 2005 | 12:34 PM
Tranman's Avatar
Tranman
Registered User
Default Tarnish like pattern on wheels..
Just got my summer wheels back on (though I know its hardly even spring yet). And there was a very odd thing on the lip of all four wheels. There is a green/purplish tarnish like stuff on the lips. I tried Mother's mag polish on them...didn't get it out. Not sure what could've caused it or if its even possible to fix...any ideas?
Old Mar 18, 2005 | 06:56 PM
Guitarman's Avatar
Guitarman
Don't know exactly what caused it, but it's corrosion of some kind, which is defined by;
"Corrosion is the destructive attack to metal by a chemical or electrochemical reaction with its environment."
My only thought is pertaining to the environment the wheels were stored in, or the combination of the storage place and a certain chemical or ingredients in a chemical cleaner or protectant product on the wheels, or used near the wheels may have caused it. Just an educated guess though.
You might try a product like TARN X on it to chemically clean it. If that doesn't work then you'll have to resort to either polishing with something different such as;
http://www.heavymetalpolish.com/Products/Polishes/
It's VERY effective in medium range (the green bottle) on bad stuff.
Last resort; wetsanding with a super-fine grit. Start out with 3000, and only go to 2000 & 1500 etc. IF it isn't working. If you must wetsand with 1500, you'll have to follow that with 2000 and 3000 then some metal polish like Heavy Metal Polish Green & Blue.
-This is of course predicated upon those wheels being bare metal ( aluminum) and NOT having a clearcoat.
If you're afraid of DIY, look for a detailer or wheel polisher, it should't cost very much to fix that. Best of luck.
Old Mar 29, 2005 | 06:00 PM
Tranman's Avatar
Tranman
Registered User
Thanks for the reply. They are clearcoated...and it has actually gotten worse now. I took it to a place where I normally get my car washed. This time around, they used a wheel cleaner...and it stained the clear coat really bad now. So it looks like I'll need to get the clear coat stripped and repolished now.
DeviousOne
Jan 19, 2008 11:05 AM
shikbas
RX - 1st Gen (1999-2003)
Mar 3, 2005 12:40 PM
poorman_nicelex
Wheels and Tires Classifieds
Oct 21, 2002 01:25 PM
