Removing console swirls
I'd like to know if anyone out there has had any experience removing the scratches on the shift console. I am thinking about just using another coat of clear polyurethane, but that takes some time to do. Has anyone got a better and easier idea?
MV
MV
What model Lexus do you have? If we knew the exact material (clearcoated wood, or plastic etc.) then I could help better. Having a GS, I'm not all that familiar with the consoles in other Lexi.
Ok then, the Lexus woods are polyurethane clearcoated, similar to the car paint itself, so...
You can use the polishes & compounds (if necessary) that you'd use on your paint. I'd first try a cheap ($3)polish like KIT Scratch Out, it's abrasive enough to level swirls, but fine enough to self polish out and not haze. Rub with moderate pressure at first, with a terry cloth applicator or towel, in straight strokes (not circles) then lighten up on the pressure with your final few passes, and see if it clears the scratching any. It won't be quick and easy, but if you take your time you should see a difference when done.
You can always go to a product like 3M rubbing compound,( which cuts faster) but it's best to use a finer polish first. The rubbing compound should always be followed by a finer polish, because it's more aggressive in grit. You can get the KIT product just about anywhere nowadays. AutoZone, Wal-Mart etc.
Cut-Throat
Jun 15, 2010 01:33 PM
jlgaustin
Oct 18, 2009 07:21 PM
