All about Lexus leather
#241
after reading through almost every single page of this thread.. I do not know why there is not a simple answer for cleaning lexus leather.. I tried a woolite/water solution with no success.. I am going to purchase some lexol, after seeing some before/after pics on here.. hopefully that will get some of these marks out, and then i will seal with mequires luxury leather protective foam..ill let you know how it works out..
#242
#243
I would have to say my seats look exactly like this but maybe a little cleaner.. the lexol looks like it worked well here.. I have the same tan leather on my gs3, and there are some grimey dirt stains from the previous owner i cannot seem to get off, any suggestions would help..
#244
I don't see the stains you are referring to in the images but I'd suggest cleaning with Leather Master Strong Leather Cleaner for starters. If that fails to remove the stains, they make a stronger cleaner called Leather Master Super Remover.
With light colored leather, it is especially important to use a leather protectant to avoid these stains and dye transfers from jeans, belts, etc. that conditioners can't. The product I use and can recommend is Leather Masters Protection Cream.
#245
1996 LS400 trim code le01
Hi, does anyone know what kind of leather dye paint I need for leather seats with Lexus trim code le01? What colour is it, exactly........tan/ivory or beige or taupe?...
Would be great if there is some help....=;o)....
TIA
plexus914
TIA
plexus914
#246
I hav yet to clean the leather in my LS but I have some experience with leather and loads of experience with various finishes and sealers (mainly for wood but also vinyl). I have seen alot of debate about the top coat on the leather and if it makes sence to use conditioners. There is truth to both arguments but the reality is that NO finish is completely non porus. Even guitar necks with 1/8" thick poly coatings breathe, discolor and warp. That poly is just abou the hardest thing around and looks and feels like a thick hard plastic but some cleaners and even air moisture migrate in and out of the wood through the finish. The same is more true of leather. The finish is infinitely thinner and more pliable and the material it covers is infinitely more porus so there is definitely some chemical transfer between conditioners and the leather, maybe not much but over time I would expect to see results.
I usually just use lexoll to clean my leather and I have had good results but the rag used to clean has to be nice and moist or it won't work right (some overlook this). Years ago I was given an old mercury marquis with leather so dirty it looked like someone just crapped on the seats and drove around working it in for years but all it took was like 1hr with the lexol and it was real real clean. Ford also uses topcoats on their crap leather and it worked well and softened up the seats quite a bit. I'll be doing the detail on the LS tomorow hopefully so I'll report my experience.
#247
I just bought a 2010 Lexus with alabaster leather. The leather is in very good shape, but I want to do a thorough cleaning and then use some protectant (Leather Masters Protection Cream). I bought the Leather Masters strong cleaner and noted it says to use it without rubbing. Can someone help me understand this? Should I just apply it and wipe it of? I tried it on a small area, and the cloth looked dirty even though that area wasn't particularly dirty. I shouldn't have any concerns about it removing the paint, should I? Finally, there are a few areas where the leather seems scraped for lack of a better word (darker leather is showing through the top ivory-colored layer). Is there anything I can do to make htis look better? Thanks in advance for your advice!
#248
Let the detergent do the work. Heavy rubbing is not desirable.
#249
The technique is to squirt some cleaner on a soft sponge and squeeze it several times to generate a foam. Gently apply the foam to a small section of the leather in brisk, circular motions using little pressure. Just enough to agitate and work the detergent into the topcoat. Let it dwell for a minute or two and wipe up with a moist, white cotton towel. Examine the towel to see if it has removed any dirt and grime. Repeat if needed and move on to another small area. When finished wet another cotton towel and wring it out then wipe down the leather to be sure to remove all traces of the detergent.
I shouldn't have any concerns about it damaging the paint, right?
Any suggestions for what to do on the parts where the paint appears to be scraped off (for lack of a better way to explain it)?
Thanks!
#250
Thanks, Jim. That makes sense. It comes out of dispenser foamy so this should be easy.
Thanks!
Thanks!
Much depends on how bad that scrape is. Can you take a couple photos of the spot? It sounds like the scrape may have removed some to the topcoat and exposed the leather. You can buy a dye kit and recoat the spot.
Another option is to find a leather restorer in your area and get an estimate. This kind of repair is usually quite inexpensive.
#251
I have no concern with this cleaner damaging the topcoat.
1) side of driver's seat back, 2) upper area of driver's seat by seat release button, 3) storage area between front seats
#254
I'd wipe the leather down with a damp cotton towel weekly or use Meguiar's Quik Interior Detailer on the towel. Every 3-6 months I'd re-clean and reapply the protection cream.
#255
I have a new LS, so I'm not looking for suggestions to cleaning stains or grime on the leather. And in my past Lexus vehicles, I've never had problems with staining or similar.
What I want to inquire about is if there is a way to keep the leather from creasing from the frequent transfer of weight across the seat when getting in and out of the vehicle. I understand that it is not possible to keep the leather looking brand new (although I would like to try for as long as possible), but I am trying to avoid the unsightly creases that appear over time.
Any suggestions on preventing or conditioning the leather to keep its new look longer would be appreciated.
