Old 12-16-14, 11:34 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
DIY: Foglight Modification
Old 02-15-10, 12:41 AM
pocky
mooncake master
pocky's Avatar
Default DIY: Foglight Modification
First, I take ZERO credit for this as I did not figure this out myself. I found the info searching the forums. The credit goes to blk250
I decided to create a new thread, since *cough* most people don't search, and I know people want to do this mod. For those of you that do not "understand the concept" of this mod, it's just personal preference, nothing else.
I originally found the information posted here by blk250.
There is also a alternative method posted here by Proper 350.
BOTH methods work, just depends on what you prefer. I preferred the rocker switch way.
Also NOTE, blk250 mentions that you can alternatively tap into the purple wire on the other connector instead of the white wire and it will work only when the ignition is switched to on. I tried this first and it does not work.
The finer details are laid out in that thread.
Excuse the photos as they are from the iPhone.
1st: Remove driver side engine cover and pop off the cover on the driver side fuse box.
2nd: Pop up the front controller box, it's held by two tabs.
3nd: Tap into the light green wire w/ silver dots.
4th: Tap into the WHITE wire on the middle connector.
Another pic of both wires tapped
5th: Tuck everything back and pull your wires through the firewall and hook it up to a rocker switch and voila!
Have fun!
Disclaimer: I take NO responsibility for you damaging your vehicle. Modify at your own risk.
eldon226 (04-14-18)
Old 02-15-10, 12:43 AM
2slow
2slow's Avatar
NICE!
pocky
mooncake master
pocky's Avatar
I know your doing it right now while typing Tim. LOL
Old 02-15-10, 12:45 AM
jadu
live.love.laugh.lexus
Forum Moderator
jadu's Avatar
niiice mod!
Old 02-15-10, 01:05 AM
joe168
joe168's Avatar
Does the factory settings still work? (i.e. drl's turn on after e-brake release, fog lights on with auto turn on of headlights and drl off, etc.). Thanks in advance!
-Joe
Old 02-15-10, 01:14 AM
poorkidlol
poorkidlol's Avatar
are those 6000k ?
Old 02-15-10, 04:26 AM
tnogi
tnogi's Avatar
Very nice and simple mod...
toHn
Old 02-15-10, 11:21 AM
brociouz
brociouz's Avatar
I think the holy grail would be if someone could wire it so that the stock foglight "switch" (the thing you rotate on the headlight stalk) would turn on the fogs no matter what setting you're on (low beams on, high beams on, auto, parking lights, etc.). Is this possible?
Old 02-15-10, 11:22 AM
quang
quang's Avatar
Looks nice!!... So is this just taping light green wire w/ silver dots and WHITE wire together? No cutting required? And where can I get those connectors/clips?
Old 02-15-10, 11:48 AM
alan003
alan003's Avatar
would like to know where to get those connectors as well.. nice mod too
Old 02-15-10, 12:21 PM
ISThree
ISThree's Avatar
i think those are the T-TAP quick wire and male spade connectors.
give pepboys or autozone a try.
i found some on ebay now.
Old 02-15-10, 12:32 PM
2slow
2slow's Avatar
Never gonna happen with a US spec BEAN ECU. The controls for the lights are multiplexed on the BEAN, and there's no simple way to separate the fogs from the headlights without extra wiring and a switch. I dug deep into this when Technique asked about it (after we figured out how to kill the link between the headlight washers and the windshield washers) and there is just no way to do it with a US spec ECU and the OEM switchgear. Sorry.
Quoted from blk250's thread.
Old 02-15-10, 12:50 PM
brociouz
brociouz's Avatar
^ that sucks.
Old 02-15-10, 01:31 PM
jbounnoi
jbounnoi's Avatar
looks dope, i wanna do this sometime..
Old 02-15-10, 08:28 PM
iSuxeL
iSuxeL's Avatar
I like this mod. But what I would like even better is when I hit the high beams my fogs don't shut off. Anyone know how to do that!? or does this mod prevent that from happening already??
Quick Reply: DIY: Foglight Modification
