Independent DYNO Proven results by "Caymandive" - no BS here!!
Old Sep 25, 2011 | 07:32 PM
  #211
ShadowISF's Avatar
ShadowISF
From the videos, Joe Z + Sikky is much louder than Borla + Sikky. Both sound good! Nice video comparison too, thanks.
Old Sep 27, 2011 | 05:24 AM
  #212
caymandive's Avatar
caymandive
11 Second Club
Originally Posted by lowrideraz
^^^^Well James, I guess I was wrong about your impression of the Borla Maybe Borla has made fitment improvements over the years. But, they still use those darn slip fit pipes with clamps. BTW, I believe the muffler rubbing the diffuser issue is more common than we may think. I am having that issue with the stock muffler on the right (passenger) side. I've cut away part of the diffuser, but there is an intermittent rubbing, so intermittent that I can live with it.
Good luck with your new setup my friend:thumb up:
Oh, and BTW, I lived in Hernden for a couple of years before I moved to Arizona. I could spit to the Sterling border from my house.
Lou
Lou,
That's kinda funny. We must have traded places since I moved to Herndon from Tucson, AZ back in 2002.
I got the exhaust taken care of yesterday. I had the shop take a look yesterday with success. Apparently during install they didn't tap the slip fit in far enough after the resonator on the driver side. A few taps and about a half inch later it pulled the muffler away from the diffuser even with the passenger side. I'm very impressed with how well the exhaust fits the car, but as a warning to others.. a slip fit design should only be installed on a lift if you don't want to beat yourself later.
Old Sep 27, 2011 | 06:42 AM
  #213
DS2k's Avatar
DS2k
Nice work James... let's meet up soon and compare exhaust sound level
Old Sep 27, 2011 | 07:03 AM
  #214
flowrider's Avatar
flowrider
Veteran: Air Force
Originally Posted by caymandive
Lou,
Yep it is. I came to Tucson at the end of '98
Lou
Old Sep 27, 2011 | 06:54 PM
  #215
mercurymet's Avatar
mercurymet
So definitely no jack stands? My problem is I don't know how I'll get the stock exhaust home after I get a dual put on. I guess I'll have it done at a shop near a u rent storage place and store it after install.
Anyhow thanks for the thread!
Old Sep 27, 2011 | 10:00 PM
  #216
ShadowISF's Avatar
ShadowISF
^^^A friend came along to help me bring the stock exhaust home in his car.
Old Oct 1, 2011 | 05:37 PM
  #217
caymandive's Avatar
caymandive
11 Second Club
Default New record best on the Dynojet Today!
Same Dynojet that I've been going to and it's known for being stingy on numbers, but I finally reached my goal of 400+whp today!
Full Thread here
I've updated my overlay to include my current setup. Keep in mind that temps, engine mileage, dyno conditions, etc are variables that the dyno correction can't always account for, but the graph will give folks the big picture, just don't judge it too closely. For instance the stock graph has a dip in the upper rpms. I'm sure this is a result of the heat and the engine pulling timing. Also the difference between the JoeZ exhaust and Borla with headers is most likely nearly identical if the conditions were the same.
Old Oct 1, 2011 | 07:55 PM
  #218
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Congratulations
Lou
Old Oct 1, 2011 | 08:16 PM
  #219
mikefate's Avatar
mikefate
Awesome. Setting goals is one thing. Achieving them is another!
Old Oct 1, 2011 | 08:38 PM
  #220
primecut's Avatar
primecut
Wow. Nice gains on the Borla. Sorry if I missed this, but on the Borla, is that a single resonator that's 2in/2out? Or is that just an enclosure with two separate pipes inside?
Old Oct 2, 2011 | 10:32 AM
  #221
LexISguy's Avatar
LexISguy
Does this mean the Borla produces more than the JoeZ?
Old Oct 2, 2011 | 11:16 AM
  #222
Joe Z's Avatar
Joe Z
NO, it certainly does not..
For further explanation as to why comparing Dyno's over a year old doesn't work, please read here:
MachV Dyno day results for 3 IS-F's
Or
Carefully read all of James' posts and dyno charts within this very same thread..
Regards,
~ Joe Z
Old Oct 2, 2011 | 05:55 PM
  #223
LexISguy's Avatar
LexISguy
Or
Regards,
~ Joe Z
Thanks Joe
Old Oct 2, 2011 | 06:01 PM
  #224
LexISguy's Avatar
LexISguy
^^^^Congratulations
Lou
Lou
Will the PPE headers yield similar results?
Old Oct 2, 2011 | 06:28 PM
  #225
ShadowISF's Avatar
ShadowISF
PPE headers will probably yield similar results as SIKKY headers.
