Finally, the long awaited reverse Red/Clear tails DIY thread
From: Sideways on the Yellow Brick Road! < Thats KS!
I was in search of some over the top custom tails that still take on a stock appearance. These hit my expectations exactly, I love them.
OK, Here it is the complete DIY for making a set of reverse Red/Clear tails. This all started as a simple little project, Zach actually gave me the idea initially. He had been toying with tail insides and outs and thus the idea was born. Lets put 95/96 insides under a 97+ lens. It all sounded like a easy task but it kinda snowballed into a small undertaking.
First lets take a look at the finished product.
OK, On with the DIY
First you need two sets of tails to pull this off (not for the faint hearted) taking two sets of preferred tails and sticking them in an oven, FUN! I started with a brand new set of 97 tails and a very nice set of 96’s
Next into the oven, I didn’t take pictures of this since it’s done time and time again. I will share my recipe since everyone has their own. Mine is 225° for 7 minutes and then gently pry them apart and reinsert in the oven for 2-3 minute intervals until you get them apart. Once apart, the real fun begins, I put them in and out and in and out and get all the old glue scraped off. I normally would not worry about it but this DIY requires a lot of together and apart check fitting.
Once apart you have to get the infamous key hole plastic off, people say pull hard, I wouldn’t, if you break the wrong part they go in the trash. I took a knife and cut around and around to control where the plastic separates.
Then I started the trial fitting, I knew I was going to use the 97 lens and the 96 insides but not sure of the backing. I messed with this for awhile, to use the 96 backing the 97 lens you have to mod the lens, I almost went this way since the 96 backing matches the inside as far as lighting goes. The other option was to use the 97 backing, to do this you have to modify it the backing, I went this way to assure a good seal. Here is some pictures of the 97 stock backing.
After a lot of trial fitting I finally figured out what all needs cut on the backing to make the 96 insides fit. Lucky you, all the research is done.
Below are the pics of what’s cut, study them.
Here is the modifications to the lens.
First take a small grinder and remove the nubs in the middle line, this is for a chrome strip I am adding; I almost put a LED strip here but decided to keep it classy.
Now for the back side, you will really have to sand it almost away at the corner. This is to make it fit in the 97 lens. See before and after pics.
Now get some red tail light spray and good quality painters tape. I use Vans tail paint, true JDM! Tape off the small reflector, since its read and the edges are orange you need to get rid of the orange. Also tape off the clear portion of the back up light.
