CA FS: RSR Blacki Coilovers with Front Exotic Air Cup
Selling my RSR Blacki Coilovers with front Exotic Air Cups and 5 gallon tank with VAir compressor. It has less then 10k miles on them. Never driven hard (I'm always on Eco mode LOL) the coilover and cups cost me 6k but I'm only asking for $2000 and buyer pays for shipping or if you live in or close to Los Angeles we can meet up
Also I am willing to just sell the coilovers for $1300 but you would need to ask RSR for a bolt that i had to trim down to make the cup to fit.
Reason I'm selling it with a low price is because I have sold my car and didn't get a chance to remove the lines and switch. Buyer needs to buy new lines and switch. In which you can contact Exotic Air or buy from any air bag company. For example http://www.universalair.com/
Exotic Air Cup- is a cylinder that uses compressed air to raise the gs 2in when you need the extra hight to go over speed bumps and ramps. Here is a link that explains the difference between Cups and Bags http://custompinoyrides.com/2013/02/...its-explained/
Blacki Coilover is the higher endline for RSR. it is design to go lower then the SportsI line
https://www.rs-r.com/product/lexus-g...oilovers-2013/
Specifications for Non F-Sport:
Preset Approximate Height From RS-R:Front -65mm (-2.5inch)Rear -80mm (-3.1inch) Maximum Adjustment Ranges:Front -45mm to -200mm (-1.7inch to -7.8inch)Rear -60mm to -145mm (-2.3inch to -5.7inch) Recommended Adjustments for Optimal Ride-ability:Front -60mm to -80mm (-2.3inch to -3.1inch)Rear -70mm to -105mm (-2.7inch to -4.1inch) Spring Rates:Front 18.00kg/mmRear 10.00kg/mm
Specifications for F-Sport:
Preset Approximate Height From RS-R:Front -60mm (2.3inch)Rear -70mm (2.7inch) Maximum Adjustment Ranges:Front -45mm to -200mm (-1.7inch to -7.8inch)Rear -65mm to -130mm (-2.5inch to -5.1inch) Recommended Adjustments:Front -50mm to -80mm (-1.9inch to -3.1inch)Rear -65mm to -90mm (-2.5inch to -3.5inch) Spring Rates:Front 18.00kg/mmRear 10.00kg/mm
slamgrayls
23
05-20-17 02:46 PM
