CA PPE header installation Help for my 08 Is350
JUst bought a PPE header few days ago from here...
but only come with 2 wires and screws,,,
do I need new gaskets?and o2 conditioners inorder to install them correctly...
without check engine light on...
A
ny advices?
A
ny advices?
Yes, you have to get the conditioner from either ppe or sikky then you have to hardwire it to your ECU I used solder for mine, I believe the color wires go to your O2 sensor wires and then ground and power of course its rather straight forward. If you dont add one you will have a CEL and trust I tried everything else like the fowlers or spacers and still had a light till I bought a conditioner...
P.s. Remember to leave enough wire to go back to stock, you will be cutting wires from your ECU unless you just tap into them like I did...
