CA FS: 98-05 GS300 Throttle Body (parts or repair)
Throttle Position Sensor - working condition
Accelerator Pedal Position Sensor - working condition
Electronic Throttle Motor - defective
Mechanical linkage & gears - working condition
You may complete this unit by simply replacing the Electronic Throttle Motor. A replacement throttle motor from rockauto is around $175 shipped, or an opened box motor off classifieds for $80. Please note that you must re-calibrate the TPS after you put everything back together.
Alternatively, you may use the working components as parts.
$100 for the entire assembly, or I'm willing to part out the working parts as well:
$65 for the APPS
$35 for the TPS
The TB assembly will only fit a 2jz manifold. As far as the sensors go, the APPS might be clocked in a different position, but I don't see why the TPS won't work.
ElitistK
07-10-13 11:30 AM
GS300Rich
01-16-11 10:26 AM
