Can I Supercharge My 95' Es300?
Old Jul 24, 2006 | 08:55 PM
SRTGT500's Avatar
SRTGT500
Exclamation Can I Supercharge My 95' Es300?
i wanna know if i can supercharge my 1995 es300. i need to do somthing to keep up with my buddies on the road. if i cant supercharge my baby does anyone have anouther solution?? im up for any ideas on how to sqeeze some quik horses outta my ES. oh and im on a tight *** budget, so it kinda needs to be cheap... but im all ears for anything so jus feed me ideas PLEASE!!!
Old Jul 24, 2006 | 09:52 PM
ssmoked's Avatar
ssmoked
wet nitrous shot and strip the car, install roll cage
Old Jul 25, 2006 | 05:09 AM
mcelligott's Avatar
mcelligott
What do your buddies drive? I have never been impressed with the trd supercharger's results on the 3.0L simply because of the price.
Old Jul 25, 2006 | 06:36 AM
Smitty's Avatar
Smitty
How hard is it to do the TRD supercharger on the ES? I was interested in this but I thought maybe there would be a problem with the timing or the transmission that would make this mod hard to do.
Old Jul 25, 2006 | 10:34 PM
3000's Avatar
3000
You can supercharge any car... except for those that are already turbo'd...
Oh yea. Some good stuff that can be done. Swap out your factory pulley's for Unorthodox racing pulleys. I had one done on my '93 (actually only the harmonic balancer) and it was better than stock. Lighten up the load (props to ssmoked ) Or... if you wanna sell the car, and get a rear wheel drive.. just kidding.
Old Jul 26, 2006 | 06:37 AM
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
what about for a 94 es? money isnt an issue, ill save up for it, but i want to get the best turbo kit i can find that will fit in my car, and the racing pulleys, where can i find them?
Old Jul 26, 2006 | 09:07 AM
VIP300's Avatar
VIP300
Does TRD make supercharger kits for the 3VZ-FE engines??? coz i've never seen or heard of this, i've only seen TRD supercharger kits for the 1MZ-FE
Old Jul 26, 2006 | 11:05 PM
3000's Avatar
3000
Aren't 94's and + 1Mzs?
Old Aug 3, 2006 | 01:50 PM
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
does any1 kno if they make them specifically for the 94 ES? if not, which good one will fit best?
Old Aug 3, 2006 | 08:44 PM
Kohinoor's Avatar
Kohinoor
i believe 94-96 1mz's have a different intake manifold, throttle body, etc
Old Aug 4, 2006 | 08:36 AM
Pheonix's Avatar
Pheonix
Cool
The 92-96 intake manifolds (For both the 3vz-fe and 1mz-fe) are a different bolt pattern to the 1mz-fe Camry/Solara engine the trd supercharger was designed for (the KAAZ/TRD supercharger fits the 98-01 engines w/o vvt-i.)
The TRD supercharger *can*, and has been modified to fit the 94-96 1mz-fe', there-hence-forth it can be modified to bolt to the 3vz-fe as well (They share intake manifold bolt pattern, along with belt routing.
The TRD S/C is the biggst piece of **i* on Earth.
To quote myself, talking on another forum...
Why the 3.0L TRD Supercharger blows (In more ways than one!)
LoL at the funny forum topic!
Just to start off with, like the forum rules say. Don't read too far into something... This isn't meant to insite a riot - so if you feel one coming on, hit your hands in the hood of your car so you can come back to the post an hour after you read it! (See I'm funny!)
Look... If your feelings are going to get hurt because I'm spelling out why the 3.0L blower constitutes a running joke in many circles or you have one & happy with it, read the last paragraph. Then come back & re-read everything later on if you get curious as to why I hope noone ever uses the 3.0L TRD supercharger without very good justification.
The TRD unit was made in Africa by Magnuson, tasked with only one priority. To get the unit to mount on the engine as cheaply as possible. This basic design philosophy not only sucks, but it created UNSOLVABLE (by Toyota) problems! (Old saying. "poop in, poop out".)
The unit produces little power, safely, without modifications, for a large cost.
The stock unit produces no boost in first gear...
The TRD unit is plug & play. What's not to love?
Yes, but that is incorrect on two major points
1) it is plug & play on SOME 1mz-fe's, not all.
2) for all but the original application years & model 1mz-fe, you will have to ahve the thing machined to fit onto the intake manifold. (Yes it can be made to fit any transverse 3.0L v6 with machining '92 3vz-fe-'01 1mz-fe including vvt-i)
The TRD unit is a safe way to gain power!
Most decidedly NOT. The TRD unit has a tendency to run lean on the LOW BOOST OEM pulley. God forbid you get tired of it's low power output & upgrade! The problem is just as bad, if not slightly worse than the 3.4L charger because there are no ready made buyable fixes for the commoners.
The truth of the matter is the stock 1mz-fe fuel system on paper can support the unit, but in practice it simply can not. This is where we get into some of the fundamental problems with the unit. The lean out problems for the 3.0L have not been widely reported on the internet so far due to low 3.0L usage - but this doesn't erase the large problem they tend to have. It were so bad, it went out of production TWICE while Toyota scrambled to pay for a "cheap fix" dealers could install/offer on the cheaply designed unit. The cheap fix never came...
But it's OK, fuel modifications are easy enough!
Ya, right. If you had a different ECU, sure no problem. But you don't - you're stuck with a fairly **** retentive ECU. Both piggybacks & standalones are known to have a hard time picking up useable signals from several sensors. When you do get them to work, you're going to have close-loop lean outs regardless.
No virgin units!
They've been out of production awhile so all that's left is used units. Life is funny, we have people buying used units from people that have blown up. Makes me wonder how many more 1mz-fe's will suffer! (You've got to see the irony in that!)
OSKSS - Over Sensitive Knock Sensor Syndrome
Many 1mz-fe's have over sensitive knock sensors that pull large amounts of timing on bone stock engines for no reason.
Charge cooling - The thing could be used as a jet dryer at a NASCAR event.
There is no good way to cool the TRD unit. TRD + 1mz = Detonation. The best way, would be to drill out the top of every runner. Then port mount them.
Tho I am not opposed to pre-"compressing hicky" water injection, I'm not sure if I could bring myself to do it with a supercharger.
Despite the widespread & popular belief, pre-turbocharger compressor water injection IS NOT detrimental to the compressor wheel in any way. (This is not my opinion, It's Garrett's. Call on of their rebuilding facilities. They have never recorded damage from the injestion of a liquid by the compressor. The head honcho turbo extraordinary of their facility in Australia also supports that & he's a hell of a lot smarter than any of us will ever be!) So... pre- Supercharger water injection probably would not hurt the unit. (Less it has like ferrite parts in it)
God forbid somebody combines hot air + a mild/medium detonation producing lean out + OSKSS YIKES!
The TRD unit is cheap!
Only first glance. In reality, unless you just get a super deal on a used unit, you still need to account for the fact you're going to need some mild/moderate fuel upgrades to safely operate it, and the more than likely many upgrades to come later on. (Let's face it... We transverse owners don't spend $2500 bucks just to get a laffable 240bhp. (Hell in all honesty, there are plenty of N/A Maxima's with modifications that would till kill us with 240bhp/260lb-ft). We buy the unit for what it can do later on. You guys are in the same boat. You don't swap in a v6 with a supercharger just to stop short leaving it at 4psi...)
The engine the unit is built for is weak. To get real goodness out of it, you're gonna be budgeting for the engine as much as you are the charger!
Nine words, fuel consumption sucks! (See nine words HAH!)
300bhp at 7psi with easy detonation problems. That is not a recipe for greatness. I don't keep up with i4's, but I'd take a stock 3s-gte + light mods over a stock 1mz-fe with a TRD charger.
And lastly... Turbo > 3.0L TRD charger.
More power, more reliability, unlimited amount of potential, and can be done safely several times cheaper if the will to do so exists.
The same arguments could & have been applied to the 3.4L TRD unit. The difference is the 3.4L unit & the 5vz-fe it blows are much easier to work with, and the problems that do exist are much easier to solve.
Don't misunderstand this post, it's nothing more than a list of some of the problems that face the 3.0L blower unit. Not that it's impossible to use for a relatively large amount of power. Anything is possible.
Yes, you can make good power with a 3.0L unit
(which doesn't change the fact that)
Yes, the other options are far better than the 3.0L unit 90% of the time.
A TRD S/C costs abot $1500 used right now, not including the management. For that, I could fab a custom turbo setup that creates infinately more power than the TRD setup ever could, across the board. From torque convertor stall (2400rpm) to fuel cut.
Drive here, give me the car for a week & be happy.
Old Aug 4, 2006 | 08:49 AM
Pheonix's Avatar
Pheonix
Cool
The TRD blower, btw is the smallest of all OEM used car blowers.
It's a stupid little M45. Those things are too small to give miata engines a descent powerband. What educated person would want to put one on a freaking 3.0L v6 that has the same rough volumetric effeciency?
If you're going to go supercharger, buy atleast a 1200 lyshlom (twin screw) blower, or atleast an M62 roots.
NOT the TRD's M45 design.
Old Aug 4, 2006 | 09:02 AM
Lexmex's Avatar
Lexmex
http://www.tte.de/popup/cm_lexus_RX3...pressorkit.htm
This is a supercharger made by TTE for the 1MZFE RX300s (oh there different engine variations in Asia for the RX300/Harrier).
I was put off by the 13,000 USD stateside price (last time I checked), and European friends were telling me in the 6 to 7K range over there.
Obviously, this is never going on my RX300 at any price.
Old Aug 4, 2006 | 10:44 AM
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
well what about for the es300? they make one for that too?
Old Aug 4, 2006 | 12:07 PM
Lexmex's Avatar
Lexmex
I did not see anything listed on their site.
