few 1jz swap aftermath questions...
I did the same thing.... i have a push button start now. Kinda a hassle, but i just need to figure out how to bypass the netural safety switch.
Find the 8-pin connector right next to the battery...you'll probably have to take the battery out. It will be mounted on the side of the black relay box. There will be two connectors here - the connector we want to splice in to, and another connector with 2 or 3 large wires. Leave that one alone.
On that 8-pin connector, find the black wire. This is the "signal" wire for the starter relay. What is happening is, for whatever reason, this wire is being supplied with 12 volts no matter if you're trying to start the car or not...and that's why the starter turns over the moment you put the battery on. Cut the black wire, leaving enough room on the CONNECTOR side to splice a wire in. Either crimp it or solder it - I'd recommend soldering - and run this wire through the firewall and down near the ECU.
Now you need to find the 1JZ "CF1" connector. It is one of the gray BODY connectors. A picture of it is here. You need to put a pin in position 8, this is the stock 5-speed starter relay activation pin. What I did was take a pin from my old 2JZ-GE harness, solder it onto my new starter wire, and push it in position 8 of the CF1 connector. Then my car started exactly as it did before the swap.
.ippyness: The master cylinder sits next to the brake booster in the engine bay.
