Accuair Elevel installs
Old 01-30-13, 01:24 PM
  #31
waijai
waijai's Avatar
Accuair provides a pretty detailed installation manual, which dictates proper mounting points and ideal amount of travel for height sensors.
Here are some pics of my instal:
http://www.dorbritzdesigns.com/2012/...accuair-e.html
Old 01-31-13, 03:08 PM
  #32
swtjlsy
swtjlsy's Avatar
Originally Posted by lbintab
Now wouldn't mounting the linkage close to the pivot point also lessen the sensitivity of the sensor detecting a change in height at any particular corner? The closer to the pivot point the less the sensor will move... Are the sensors sensitive enough to see even mm of change in travel of the linkage?
Yes they are. The system is always looking for adjustments along with recalibrating every 45 seconds for loads changes.
Old 01-31-13, 03:17 PM
  #33
swtjlsy
swtjlsy's Avatar
Dortbiz Design does great work, and there systems are well installed and thoughtout before installation. They did a nice job on your car. We here at accuair strive to make our set up as user friendly as possible. The Maunal that we provide with each an and every kit is a full color diagram of how each componet should be be connected not how it should be installed since every car is different for the location of the ride height sensors. That would why we state to place the snesor as close to the pinch point as possible. YOu will need to have some travel but not the full 2.75 inches as with the first Gen sensors. You now can have form 1-4 inches of travel with the 2nd Gen sensors which should now make it a lot easier to install. I you have nay other question Please ask.
Old 03-03-13, 09:55 PM
  #34
lexusondubs
dubsonlexus
lexusondubs's Avatar
Originally Posted by swtjlsy
The e level is self leveling so there is no adjustment also long as the four corner sensors are mount in the same area as each side. there are several members on here who have had them install I have yet to do a LS but if I saw the underside I could help you out. PM when youare ready to get something and I can help with the install.
pm sent
Autrey
03-24-19 12:53 PM
Autrey
01-17-19 12:59 PM
racing2987
11-08-18 04:38 PM
tmr mc
07-30-06 03:55 AM
pwebber
06-20-06 03:16 PM
Quick Reply: Accuair Elevel installs
