Stoptech drilled and slotted rotors on an 06 IS350
Old 06-08-15, 05:50 AM
Gsr1981
Gsr1981's Avatar
Default Stoptech drilled and slotted rotors on an 06 IS350
Question: Anyone ever replace their OEM rotors with the stop tech drilled and slotted rotors? Did they fit exactly like the OEM rotors? The ones I bought were from Amazon and they are 11 inches and the stock OEM rotors on my iS350, is exactly 13 inches. Half of the brake pad is only covered by the stop tech rotors, when the OEM ones cover the entire brake pad. Anyone knows where I could find a pair of 13 inch drilled and slotted rotors only? Because obviously Ebay and Amazon has retarded parts that don't match to OEM standards?
Stock rotors at the bottom, stoptech on top.
stock OEM rotors
stoptech 11" rotors
this is with the stoptech rotors, only half of my brake pads are covered, so with wear and tear it's gonna be sitting on top of my rotor destroying the rotor.
just too small won't fit. Stoptech smh.
closer look at the pads sitting in the stoptech rotors.
Old 06-08-15, 11:15 AM
Bartman619
Bartman619's Avatar
Yeah, it looks like they probably posted the wrong size on Amazon. Return them and try Tirerack.
Old 06-08-15, 06:56 PM
Gsr1981
Gsr1981's Avatar
Thanks dude, appreciate that.👍🏾
Old 06-08-15, 08:08 PM
NYKnick101
NYKnick101's Avatar
Looks like they sent you the one for the 250 not 350
Old 07-14-15, 06:25 PM
ltendayte
ltendayte's Avatar
Old 07-15-15, 10:28 AM
cquence
Former Sponsor
cquence's Avatar
NYKnick101 is correct; it does look like they sent you the IS250 rotors. Not sure how that happened but Amazon's compatibility list seems to be notorious for pulling up the wrong parts in their results list. I'd recommend confirming the specs with the seller before actually purchasing to avoid mishaps like this and hope the seller provides you a full refund.
ABurns250
Suspension and Brakes
10-12-11 03:43 PM
jazba
08-03-09 06:41 PM
rclab1
04-03-07 10:54 AM
NotFatBoy
11-18-06 03:04 PM
timoc42
04-04-04 03:19 PM
Quick Reply: Stoptech drilled and slotted rotors on an 06 IS350
