Staggered 16"
Old 08-27-03, 05:00 PM
oldmonk
oldmonk's Avatar
Question Staggered 16"
Does this sound like a decent set-up?
16x8 wheels with 225/55-16 tires on the front and 245/50-16 tires
on the rear. Or should I just run the stock 225/55 on all four corners?
Please let me know any possible benefits and/or drawbacks.
Thanks in advance.
Old 08-27-03, 05:39 PM
JacobT
JacobT's Avatar
There's not much difference between 50% and 55% side wall with +20mm contact patch. And you will lose the capability to rotate your tires. I'd say just keep 225/55 on all 4 corners.
Old 08-28-03, 12:39 PM
mmcustom
mmcustom's Avatar
keep the stockers!
Old 08-28-03, 01:17 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Default 17 Inch
I would stay with the stock size unless you want to upsize your wheels to 17 or 18 inch.
Old 08-30-03, 08:47 PM
oldmonk
oldmonk's Avatar
Question Best way to go with 16x8 wheels
What about this 16x8 wheel with a +42mm offset and 225/55-16's all around?
How does the +42 offset affect my car vs. the stock 50mm?
Since the wheel is 8 inches wide, would I be better off running 245/50-16
rubber at all four corners?
Old 08-31-03, 08:01 AM
Received 2,128 Likes on 1,380 Posts
You have aftermarket 16's? The lower offset will bring the wheel OUT of the fender well some, which will look better (more flush with the side).
estomax
SC- 1st Gen (1992-2000)
18
05-14-20 10:07 AM
SylvesterM
01-10-18 07:15 PM
defo
08-13-13 10:15 PM
aau
08-14-12 05:34 AM
dshea
12-03-03 06:42 PM
Quick Reply: Staggered 16"
