camber wear...can I swap tires?
Old 05-10-03, 03:36 PM
howiedoit
howiedoit's Avatar
Default camber wear...can I swap tires?
I have some camber wear on the inside of my rear tires. I'm wondering if I can have a shop put my right tire on the left wheel and the left tire on the right wheel. That way, the less worn sides of the tires will be on the inside. Is this a good move to extend tire wear? Will it cause problems?
Old 05-11-03, 07:55 PM
howiedoit
howiedoit's Avatar
does anyone know?
Old 05-11-03, 08:55 PM
Received 2,128 Likes on 1,380 Posts
If you have directional tread you can't do it. I vaguely recall that even if you don't that it may not be advisable to have the tires travel in the opposite direction they have been running in.
Old 05-11-03, 09:07 PM
howiedoit
howiedoit's Avatar
I have Kumho Ecsta Supra 712's. If I just swap the left and right tires, won't the directions still be going the same way?
Old 05-12-03, 03:34 AM
TLEX
TLEX's Avatar
Yes you can do it. I've done it on my Accord. They will still be going in the same direction if you switch the left to right, just not from front to rear. So now the camber will just be on the other side of the tire.
Old 05-12-03, 08:23 AM
No they won't be going the same direction if you swap the front wheels unless you take the tires off the wheels!!!
Old 05-12-03, 03:02 PM
TLEX
TLEX's Avatar
Bit,
That was his question in his first post. He asked if he can take the tire off of the wheel and switch them.
Old 05-12-03, 03:45 PM
///MDex
///MDex's Avatar
Default Re: camber wear...can I swap tires?
Yes, you can do that. But be careful in that your handling charateristics may be a bit odd until the wear surface evens out. Also, find the root cuase of the uneven wear while your at it.
Old 05-12-03, 05:12 PM
Originally posted by TLEX
Bit,
DOH you're right, sorry howie.
Old 05-12-03, 07:56 PM
howiedoit
howiedoit's Avatar
heh...no problem. sorry for the confusion. i know the root of my problem...but the camber is just off slightly. it's within spec, but the tires still wear a little uneven. thanks guys!
Bullskim
11-15-09 12:32 PM
areukhmer
01-31-09 01:08 PM
jasonm
12-04-08 12:06 PM
blklexo818
Suspension and Brakes
50
10-22-08 02:54 PM
nardeezy
07-26-08 08:36 PM
Quick Reply: camber wear...can I swap tires?
