Slow leak on One tire
Hi,
I'm facing a slow leak problem on my 13 ES350. I've been reading a lot of posts here and thought I could just rebuild the TPMS valve stem with a new core, nut, etc. I took my car to my mechanic and he couldn't find any actual leaks on the tire but he also told me that because the TPMS and the valve stem are one-piece, that it is impossible to rebuild the it since you can't take it off of the TPMS sensor itself. This didn't make any sense to me because I found TPMS rebuild kits for my car on eBay http://www.ebay.com/itm/TIRE-PRESSURE-SENSOR-REBUILD-TPMS-TPS-SERVICE-PACK-KIT-WITH-NUT-VALVE-CAP-GASKET-/251189537345?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ALexus&hash=item3a7c102a41&vxp=mtr
First, is it actually possible or do I need a new TPMS sensor/valve stem and pay for the reprogramming? Second, should I just take it to a local tire shop and ask them to rebuild it? Or go to another mechanic?
Thank you.
Thank you.
Hi,
I'm facing a slow leak problem on my 13 ES350. I've been reading a lot of posts here and thought I could just rebuild the TPMS valve stem with a new core, nut, etc. I took my car to my mechanic and he couldn't find any actual leaks on the tire but he also told me that because the TPMS and the valve stem are one-piece, that it is impossible to rebuild the it since you can't take it off of the TPMS sensor itself. This didn't make any sense to me because I found TPMS rebuild kits for my car on eBay here
Thank you.
Thank you.
Well that kit is like $6 and a valve stem remover is also $5 so if it is possible to replace the valve stem core then I would like to give that a try... Just want to confirm what my mechanic said is true or not
I too would like to know if anyone has more info on this as I'm currently experiencing the same issue with just my front right tire. I've taken it to two shops now and both have not found any nails or problems with the tire but the leak still remains as I'm having to add air every few days or so. Is it something with the wheel? I know both work wheels and nitto tires are good quality brands. Don't know why this is happening? If someone could please help!
Wheel Corossion
Could be wheel corrosion. I am replacing the Foose wheels after 6 years which replaced the Lexus wheels due to corrosion on the inner lip of the front wheels. If its front wheels it may be that. They can check by breaking down the tire and wheel and inspecting the inside of the rim.
tfeni52355
10-07-08 07:13 PM
