22's on LS400
Old 05-11-10, 08:38 PM
Mesca
Mesca's Avatar
^ Sorry but IMO that just looks ridiculous..
Old 05-12-10, 04:01 AM
Schnitz
Schnitz's Avatar
Yes 22's will fit. Whether they look good is up to you. I don't like'm.
Old 12-03-11, 06:08 AM
gmc3024
gmc3024's Avatar
i agree the 22" does fit i put them on my 90 and it looked great will post a pick later and just bought a 96 thinking of getting 22" also i like the Mrr hr3 but they dont come in 22"
Gmatic (04-09-20)
Old 02-15-12, 03:01 PM
Lexo1986
Lexo1986's Avatar
This is my 93 on 22s what y'all think http://i111.photobucket.com/albums/n.../chrisride.jpg
Old 03-21-15, 04:38 PM
Dwaystylez
Dwaystylez's Avatar
Default 1996 ls400
How can I make my 22 inch rims fit my 1996 LS400 and how much would it cost me.
Old 03-22-15, 08:36 PM
MrMark
MrMark's Avatar
Please don't......
Old 03-24-15, 10:43 AM
01LexPW
01LexPW's Avatar
19's should look on point.
Old 03-24-15, 11:42 AM
RA40
Super Moderator
RA40's Avatar
If that intent, you'll need to have the fenders cut-shaped to clear the overall diameter of the combo. Cost depends how deep your wallet is. Also to have in mind is that the weight of the wheels add stress to the suspension and brakes.
If the bushings are not in good shape now, they thump-clunk and possibly be metal on metal. An alignment will be impossible and those $$ tires will wear out pretty quickly. On an old LS, typical pats are: strut rod bushings, inner outer tie rods, ball joints, upper and lower control arm bushings.
As for braking stress: the stock combo come in around 50#'s. The rough calculation for rotational weight is that for every 1# added at the wheels varies depending based on location but roughly translates to about 8#'s. The shocks are not calibrated to dampen that weight. Many 22' combos weigh in at ~70-80#'s and stopping takes lots more pedal pressure-pad wear, increased heat and longer stopping distances.
The other we don't talk about is driveline stress. Breaking an axle spline or tooth/teeth in the differential is also an added possibility. The carrier bushings also dampen some of the added mass added at the wheels.
Just want to bring awareness that there are other considerations than just big wheels involved.
Old 04-09-20, 06:03 AM
Gmatic
Gmatic's Avatar
Default 22's
Tucked on 22's, Nice!
Old 05-08-20, 08:44 PM
brendenS
brendenS's Avatar
Default tires
what size tires and offset do you have
Old 07-26-23, 06:51 AM
jones41
1st Gear
jones41's Avatar
19's on 1991
19's on 1991
Bassil
09-21-10 07:40 PM
RandySC400
25
03-19-09 02:04 PM
sirblinks
12-02-08 06:50 PM
Lac
01-04-05 05:25 AM
Quick Reply: 22's on LS400
