How to calculate offset?
Old 10-13-10, 02:10 PM
speeds27
speeds27's Avatar
Default How to calculate offset?
So i have a set of wheels and i'm trying to calculate the offset. From my understanding, the offset is the wheel backspace minus the wheel centerline multiplied by 25.4 to get it into mm.
So the set of wheels i have are the following.
Wheel Width = 9
Wheel Center Line = 4.50
Wheel Backspace = 5.75
Thus = 5.75 - 4.5 = 1.25 * 25.4 (to convert to mm) = 31.75
But according to this graph from rsracing.com, it says with a wheel width of 9 and a backspace of 5.75, the offset should be 19
Now i know i'm not the brightest crayon in the box, but whats up with my math?
https://www.rsracing.com/tech-wheel.html
Measuring Wheel Offset
To calculate offset you'll need the following measurements:
Wheel backspace
Wheel Width
Wheel Center line (outboard flange to inboard flange measurement / 2)
Subtract:
Wheel center line from Wheel backspace to get offset.
If backspace is less than the wheel centerline the offset is negative
If backspace is greater than the wheel centerline the offset is positive
Tip:
To convert from inches to mm multiply by 25.4
To convert from mm to inches divide by 25.4
Old 10-13-10, 02:47 PM
rominl
exclusive matchup
rominl's Avatar
i will give this one a try. it has to do with definition i think, and you can also see it from the following picture
definition of wheel width is not outboard flange to inboard flange, but instead, outboard bead seat to inboard beat seat. so when you do the flange to flange, it's not the wheel width, and they seem to add about 1/2" to each side (1" in total).
so for example, a 10" wheel, the flange to flange is actually 10"+0.5"+0.5" = 11" (center line 5.5"). that's why when you look at the table, if you have a 10" wheel and the back space is 5.5", your offset is zero.
using the same idea on your example, for a 9" wheel, the flange to flange is 10", center line 5". back space 5.75", so offset is +0.75", which is +19mm
Old 10-14-10, 01:58 AM
speeds27
speeds27's Avatar
Thanks for the clarification rominl. I think i got what you're saying. So lets see if i have this correct.
I have a staggered set.
Front wheels are 8.5 (flange to flange 9.5)
5.75 (wheel backspace) - 4.75 (center line) = 1 * 25.4 = 25.4 offset
Rear wheels are 9.5 (flange to flange 10.5)
7 (wheel backspace) - 5.25 (center line) = 1.75 * 25.4 = 44.45 offset
Old 10-14-10, 08:51 AM
rominl
exclusive matchup
rominl's Avatar
i think that sounds right
Old 11-02-10, 10:27 AM
ClearP
ClearP's Avatar
This clarified a few things for me!
Rominl, do you mind me using your "Support Authenticity" Avatar and your signature?
Old 11-02-10, 01:57 PM
rominl
exclusive matchup
rominl's Avatar
hahhaa of course no problem, please feel free
Old 11-02-10, 04:51 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Why not just put on a flat surface, measure the width with a ruler through the center bore, divide by 2, then use another straight edge to calculate the difference between the center line of the wheel and the mounting flange, while you still have the ruler sticking up through the center bore. Use the MM side of the ruler also.
Old 11-02-10, 05:38 PM
ClearP
ClearP's Avatar
Thanks Rominl!
kkoophoto
RX - 4th Gen (2016-2022)
02-04-19 08:19 PM
GS FONZy
01-11-07 01:51 PM
jamecl
04-17-01 04:38 PM
Quick Reply: How to calculate offset?
