Confliciting info on tire pressure on my new IS
Please delete.
Last edited by is250tx; 12-30-09 at 03:17 PM. Reason: Meant to post in IS forum - my bad.
Didnt want to make another thread and clutter up the forums so I thought Id post my question here since it relates to tire pressure. Im running 245/35/19 and 275/30/19 tires right now and the max psi is 50. Now I was told to run 40 psi which seems really low. Can I get some help on this? Should I be at 50 psi? Also, do I need to go with a lower or higher psi in cold/hot weather?
Former Sponsor
Even 40 is a little higher prob then what is on the placard, but as long as you don't go over the max on the sidewall you should be fine. Keep in mind these numbers are "cold" meaning in the moring before you have driven on them.
